dfelz |
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California ![]() ![]() |
Just split my case, trying to pull the crankshaft from the case half but on the flywheel mounting side it does not want to budge at all from the case! The impeller side is free, but all my efforts of trying to break free the other side did not prevail. Even tried turning the case upside down, with helper holding the crank from the bottom, and me giving some good wacks with the rubber mallet to the top of the piston rod closest to the flywheel from the top, hoping gravity would help, but that still didn’t work... anyone else come across a tight crank that would separate??
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,490 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Pull it apart, now you need to know why it is not coming apart with all the effort you have put into that end. Even when mine grenaded, the crank came out with little effort. No more than a few whacks normally.
Lo-Fi Version | Time is now: 26th June 2024 - 06:29 AM |
