collinvon |
Newbie ![]() Group: Members Posts: 42 Joined: 11-June 19 From: St. Paul, Minnesota Member No.: 23,207 Region Association: Upper MidWest ![]() |
Looks like I found where all the oil has been coming from. I cleaned the engine as well as I could with a degreaser, ran it for 5 minutes at idle, and was able to spot a substantial leak coming out of the push rod tubes:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23207-1560976029.1.jpg) I'm going to tackle this project this weekend. I've found some good older articles that mention it can be done without dropping the engine, but might have to replace the seals on a couple without fully removing them. I'm going to replace the valve cover gaskets, adjust the valves for the first time, and I'll being doing the first oil change since I've had it. I've heard Valvoline ZR1 20W-50 is a good oil to use, and I can find it locally. Thoughts? Aside from ensuring I don't damage the seals on reinstallation, and thoroughly cleaning everything, anything else I should keep in mind, or try to tackle while I'm in there? Any other tips and tricks are much appreciated. Thanks in advance for any feedback. |
isdyl |
Member ![]() ![]() Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England ![]() |
Thanks but I still need to get a new tube back in. Although I've bought a new set of tubes, I I'm considering repairing the hole in the tube now to avoid moving the engine. Does anyone know what temperature these tubes get to please?
Thanks |
Lo-Fi Version | Time is now: 25th June 2024 - 12:35 AM |
