FRUNKenstein |
Member ![]() ![]() Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest ![]() ![]() |
I’ve spent the past couple of hours searching here and surfing the web on LED headlight replacement/conversion. I see the GE Nighthawk 69821 was used by several folks, but they are expensive and no one seems to have them in stock. I think they’ve been on the market for 5+ years, so assume there are competitors. I read on a Mustang forum that the Truck-Lite 27270C is a good alternative for 7” sealed beams. I looked on Spoke’s website, but he doesn’t offer headlights, so I assume there is a good, readily-available product on the market already, or else he would have something.
So, can anybody give me an update on the latest and greatest in LED headlights? Thanks in advance! |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,352 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
You want the GE / Trucklite split style for excellent beam patterns.
Everything I've seen under $100 has been a bad chinese copy with a spotty pattern. The LED bulb in a H4 housing hasn't been good either, too much glare, specially for the 914 in front of you. Specially if it's a DOT H4, which by law puts 20% of the light upward to light overhead signs. If you just want a decent step up from stock sealed beam the Hella H4 E-code works. Add relays, which you should do anyways, and you can go up to a 80/100w bulb. |
Lo-Fi Version | Time is now: 30th June 2024 - 08:16 AM |
