FRUNKenstein |
Member ![]() ![]() Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest ![]() ![]() |
I’ve spent the past couple of hours searching here and surfing the web on LED headlight replacement/conversion. I see the GE Nighthawk 69821 was used by several folks, but they are expensive and no one seems to have them in stock. I think they’ve been on the market for 5+ years, so assume there are competitors. I read on a Mustang forum that the Truck-Lite 27270C is a good alternative for 7” sealed beams. I looked on Spoke’s website, but he doesn’t offer headlights, so I assume there is a good, readily-available product on the market already, or else he would have something.
So, can anybody give me an update on the latest and greatest in LED headlights? Thanks in advance! |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Retrofitting FED bulbs within existing lenses is not a proper solution since the LED is not in exactly the same location as the filaments were before. Thus the lense will not focus the beam properly. You lose beam effectiveness, and people coming at you can be blinded. The correct solution is a bolt in headlight assembly that is correctly designed.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Retrofitting FED bulbs within existing lenses is not a proper solution since the LED is not in exactly the same location as the filaments were before. Thus the lense will not focus the beam properly. You lose beam effectiveness, and people coming at you can be blinded. The correct solution is a bolt in headlight assembly that is correctly designed. OEM was sealed bulb There are housings designed for LED application |
Lo-Fi Version | Time is now: 2nd July 2024 - 06:40 AM |
