What’s the Latest on LED Headlight Conversion? |
FRUNKenstein |
Dec 13 2020, 02:55 PM
Member Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest |
I’ve spent the past couple of hours searching here and surfing the web on LED headlight replacement/conversion. I see the GE Nighthawk 69821 was used by several folks, but they are expensive and no one seems to have them in stock. I think they’ve been on the market for 5+ years, so assume there are competitors. I read on a Mustang forum that the Truck-Lite 27270C is a good alternative for 7” sealed beams. I looked on Spoke’s website, but he doesn’t offer headlights, so I assume there is a good, readily-available product on the market already, or else he would have something.
So, can anybody give me an update on the latest and greatest in LED headlights? Thanks in advance! |
Cairo94507 |
Dec 16 2020, 03:24 PM
Michael Group: Members Posts: 9,863 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Hi Pete, @horizontally-opposed , Zach, @VaccaRabite , is hitting an issue not previously discussed which we had to deal with on my GE Nighthawks. They protrude further out of the housing then a stock sealed beam or H4 lens. That is why when you look at my car or see it in pictures it looks like the gap for the eyebrows and the headlight cover is just off a bit. Kent & Jim had to adjust the eyebrows to allow the headlights to open/close without hitting the eyebrows. The headlight sticks out maybe 3/16" to 1/4" further than stock.
But considering the GE's are 100% plug and play with no alterations or extra wiring, etc., I decided that was the way to go. Now, if someone makes an LED headlight that looks period correct and does not protrude and is plug and play....I would likely swap to that. Then we could re-adjust the eyebrows to fit 100% correctly. Not high on my list, but on the list. I like the look of the Vintage lights a lot - I would go with the Hella H4 lens in the 5000 series and run them with the bright white color. Price wise they seem to be about the same as the GE's at today prices. That leaves the truck light options- and there has got to be tons, like Zach said. Keep us informed of how you proceed. I do love, love, love the light my Nighthawks put out. It's like the factory headlights were candles. The older I get the more light I need to see anything. (IMG:style_emoticons/default/beerchug.gif) |
FRUNKenstein |
Dec 16 2020, 03:29 PM
Hi Pete, @horizontally-opposed , Zach, @VaccaRabite , is hitting an issue not previously discussed which we had to deal with on my GE Nighthawks. They protrude further out of the housing then a stock sealed beam or H4 lens. That is why when you look at my car or see it in pictures it looks like the gap for the eyebrows and the headlight cover is just off a bit. Kent & Jim had to adjust the eyebrows to allow the headlights to open/close without hitting the eyebrows. The headlight sticks out maybe 3/16" to 1/4" further than stock. But considering the GE's are 100% plug and play with no alterations or extra wiring, etc., I decided that was the way to go. Now, if someone makes an LED headlight that looks period correct and does not protrude and is plug and play....I would likely swap to that. Then we could re-adjust the eyebrows to fit 100% correctly. Not high on my list, but on the list. I like the look of the Vintage lights a lot - I would go with the Hella H4 lens in the 5000 series and run them with the bright white color. Price wise they seem to be about the same as the GE's at today prices. That leaves the truck light options- and there has got to be tons, like Zach said. Keep us informed of how you proceed. I do love, love, love the light my Nighthawks put out. It's like the factory headlights were candles. The older I get the more light I need to see anything. (IMG:style_emoticons/default/beerchug.gif) I have an X1/9 that will have all of the exact same issues you discuss. I'm starting with the 914 since there is a stronger community supporting that vehicle. Once I get the 914 headlights sorted out, I'll take the lessons learned and apply to the X1/9. |
Lo-Fi Version | Time is now: 30th June 2024 - 08:19 AM |
