McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I'm in the process of installing the Beta KitCarlson EMS. Today it ran. I've been working on modifying the wiring harness to match the stock layout. I had one wire in the wrong place today which made it keep running even when the key was off. Fixed that and now it idles great.
Things I've done so far: - Modify the wiring harness. - Buy plug wires that will work with the new coil. - Made an adapter plate to mount the coil in the stock location. Things I still have to do: - Send the harness to Jeff B. for replication. - Fine tune the engine. - Make a mounting plate for the brain to put it in the stock location. |
McMark |
Well it fluctuates between 350 and 550 as the RPM changes. It's set at 10 degrees right now. Maybe I should set it at 12 degrees. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 06:58 AM |
