FRUNKenstein |
Member ![]() ![]() Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest ![]() ![]() |
I’ve spent the past couple of hours searching here and surfing the web on LED headlight replacement/conversion. I see the GE Nighthawk 69821 was used by several folks, but they are expensive and no one seems to have them in stock. I think they’ve been on the market for 5+ years, so assume there are competitors. I read on a Mustang forum that the Truck-Lite 27270C is a good alternative for 7” sealed beams. I looked on Spoke’s website, but he doesn’t offer headlights, so I assume there is a good, readily-available product on the market already, or else he would have something.
So, can anybody give me an update on the latest and greatest in LED headlights? Thanks in advance! |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
My issue with the VintageCar LED is different then Cairo's issue with the nighthawks. His issue is with the front of the lens, and mine is with the backside (where the sun don't shine).
![]() I did not have a pic of mine, so I used a pic off the VintageCar LED website. Their bulbs have the big heat sink as shown, and this sticks out about 2 inches from the back of the lens. You can make it fit in a 914 bucket. Many have including me. But for a 914 it does not fit RIGHT. Then VintageCar lenses are fine. Great even. Fit right in, and look 100% period for the 70s (especially when you buy the "classic" lens, which I did for a small upcharge). Vintage Car used a bulb and lens approach similar to an H4. The LED bulbs are long and stick well out behind the back of the headlight lens. So much so that the headlight and heat sink is pressed firmly against the sheet metal that makes up the headlight cover when the lights are down. In effect, when you adjust the lights, they are bearing not against the housing frame, but the back of the bulb heatshield is the bearing point against the sheet metal of the headlight cover. On a car that does not have very shallow headlight housings (like a bug or 911, etc) these bulbs would not have a single issue. On a 914 with our shallow buckets, it is an issue. - at least with the lenses I bought. Zach |
Lo-Fi Version | Time is now: 30th June 2024 - 08:11 AM |
