> Time to un-DAPO the "new" car, Bad things happened to a nice car
BillC
post Jun 27 2020, 11:30 AM
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole:
Once I took the rockers off, I discovered this:
Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is.
In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location).
BillC
post Dec 6 2020, 12:13 PM
And . . . done!
It even works!
I need to finish cleaning up and painting this side, then it's on to the other side (joy. (IMG:style_emoticons/default/headbang.gif) )
Superhawk996
post Dec 21 2020, 09:01 AM
QUOTE(BillC @ Dec 6 2020, 01:13 PM) *
And . . . done!
No getting off that easy. (IMG:style_emoticons/default/happy11.gif) Do tell . . . . How did you weld the top? I'm assuming MIG with blind point & shoot approach?
I've got a similar situation but will need to TIG. I'm really debating about removing the top 1/2 of the pyramid. I want full fresh metal in there but I think it's going to be almost impossible to weld the top. Having said that the welds along bottom and side would be more than enough to provide a functional support. Maybe just seam seal the top and be done with it. (IMG:style_emoticons/default/idea.gif)
BillC   Time to un-DAPO the "new" car   Jun 27 2020, 11:30 AM
Montreal914   Front mounted oil cooler or AC? :confused: Look f...   Jun 27 2020, 11:32 AM
SirAndy   Front mounted oil cooler or AC? :confused: Look ...   Jun 27 2020, 11:43 AM
BillC   Front mounted oil cooler or AC? :confused: Look ...   Jun 27 2020, 12:06 PM
BillC   But, so far, the "best" has to be the ho...   Jun 27 2020, 12:16 PM
SirAndy   I cut it off with a pair of snips. I'll take ...   Jun 27 2020, 03:01 PM
BillC   [quote name='BillC' post='2828616' date='Jun 27 2...   Jun 27 2020, 05:22 PM
BillC   And, in the archaeology department, here's a c...   Jun 27 2020, 12:23 PM
BillC   It turns out that the car may have it's origin...   Jun 27 2020, 12:27 PM
preach   It turns out that the car may have it's origi...   Jun 27 2020, 05:49 PM
Chris914n6   The foam is factory correct for an early car. It...   Jun 27 2020, 12:30 PM
BillC   The foam is factory correct for an early car. It...   Jun 27 2020, 12:44 PM
mepstein   The foam is factory correct for an early car. It...   Jun 27 2020, 04:11 PM
ClayPerrine   [quote name='BillC' post='2828626' date='Jun 27 2...   Jun 27 2020, 04:46 PM
ClayPerrine   Trying to "Un-DAPO" the car. I am sti...   Jun 27 2020, 03:17 PM
Cairo94507   I hope they disclosed all of those issues prior to...   Jun 27 2020, 05:42 PM
BillC   I hope they disclosed all of those issues prior t...   Jun 27 2020, 06:06 PM
BillC   So, continuing down the list of discoveries: Ther...   Jun 27 2020, 06:23 PM
barefoot   The 1.7/1.8 SS heat exchangers have the same tub...   Jun 28 2020, 01:35 PM
BillC   The 1.7/1.8 SS heat exchangers have the same tu...   Jun 28 2020, 05:48 PM
BillC   So, we got the engine and fuel tank out yesterday....   Jun 29 2020, 10:56 AM
SirAndy   For what it's worth, i really like the color...   Jun 29 2020, 12:25 PM
BillC   For what it's worth, i really like the color...   Jul 1 2020, 04:12 PM
Craigers17   This situation seems particularly frustrating....e...   Jul 1 2020, 04:43 PM
Superhawk996   This situation seems particularly frustrating.......   Jul 1 2020, 05:02 PM
BillC   This situation seems particularly frustrating.......   Jul 1 2020, 05:22 PM
2mAn   :WTF: :chair:   Jul 1 2020, 04:56 PM
Wyvern   When I started reading this I did not know what a ...   Jul 1 2020, 05:03 PM
BillC   Made more progress today. Removed the rear window...   Jul 2 2020, 05:19 PM
Montreal914   Not sure what your front sway bar setup is but I d...   Jul 2 2020, 05:50 PM
BillC   Not sure what your front sway bar setup is but I ...   Jul 2 2020, 05:53 PM
BillC   It doesn't seem like I accomplished much today...   Jul 3 2020, 04:44 PM
BillC   Well, I didn't make as much progress as hoped ...   Jul 6 2020, 04:26 PM
Cairo94507   Very nice. You are making great progress and tack...   Jul 6 2020, 05:54 PM
Front yard mechanic   If you ever sell the car think what the next owner...   Jul 6 2020, 08:07 PM
BillC   If you ever sell the car think what the next owne...   Jul 7 2020, 06:36 AM
Superhawk996   If you ever sell the car think what the next own...   Jul 8 2020, 06:40 AM
get off my lawn   If you ever sell the car think what the next owne...   Jul 7 2020, 03:20 PM
IronHillRestorations   Sad to see the misfortune of some cars. I hope my...   Jul 7 2020, 03:16 PM
BillC   The order with the rubber isolator finally came, s...   Jul 9 2020, 07:08 PM
BillC   Today I worked on reinstalling the fresh air box. ...   Jul 11 2020, 04:19 PM
BillC   Time to tackle the hacked-in hole by the foot peda...   Jul 12 2020, 02:39 PM
914werke   Good idea on the Wire support.   Jul 12 2020, 03:00 PM
Superhawk996   Like the wire support execution. My donor tunne...   Jul 12 2020, 03:58 PM
BillC   Like the wire support execution. Thanks, but it...   Jul 12 2020, 07:17 PM
ClayPerrine   Like the wire support execution. Thanks, but i...   Jul 12 2020, 09:50 PM
BillC   And now, let's go after this lovely bunch of h...   Jul 13 2020, 07:17 PM
BillC   The lovely bunch of holes, continued: Here's ...   Jul 13 2020, 07:29 PM
Superhawk996   :trophy: Like the screw as a handle. Still had ...   Jul 14 2020, 07:50 AM
BillC   Like the screw as a handle. Still had to have bee...   Jul 14 2020, 12:35 PM
kroelofsen   :Qarl: Nice work...!   Jul 14 2020, 11:53 AM
bkrantz   Be fair! I am sure most 914s were free of rus...   Jul 14 2020, 08:29 PM
BillC   Be fair! I am sure most 914s were free of ru...   Jul 15 2020, 04:34 PM
BillC   Time to do more work on the fuel system. First, n...   Jul 17 2020, 04:52 PM
barefoot   Next, is to mount the fuel pump and fuel filter. ...   Jul 18 2020, 02:13 PM
Superhawk996   :cheer:   Jul 18 2020, 08:43 AM
Cupomeat   Love this thread! Thankfully I've had my 9...   Jul 18 2020, 09:05 AM
BillC   Love this thread! Thanks! Sometimes I w...   Jul 18 2020, 06:27 PM
bkrantz   Love this thread! Thanks! Sometimes I ...   Jul 18 2020, 08:33 PM
BillC   Did you consider mounting the pump on the undersi...   Jul 19 2020, 05:51 AM
BillC   Anyway, finally got the pump, filter and hoses ins...   Jul 18 2020, 06:27 PM
BillC   So, the parts I've been waiting for finally ar...   Jul 23 2020, 02:11 PM
Superhawk996   Here are the pliers reassembled and holding a r...   Jul 23 2020, 02:33 PM
BillC   Last night, I glued the perlon back on the front b...   Jul 24 2020, 03:27 PM
BillC   This is what the battery tray looked like: This i...   Jul 26 2020, 10:38 AM
Frankvw   good trick with adjusting these pliers ! Ques...   Jul 27 2020, 01:05 AM
BillC   good trick with adjusting these pliers ! Que...   Jul 27 2020, 02:20 PM
Frankvw   "If you want, I'll take more pictures of ...   Jul 27 2020, 02:25 PM
BillC   Well, it's been too long, but I finally had a ...   Aug 9 2020, 06:32 PM
porschetub   you have great metal fab skills,well done but expe...   Aug 9 2020, 09:14 PM
BillC   Didn't plan on it taking so long for this next...   Aug 23 2020, 06:02 PM
BillC   Well, it's been waaaay too long since I made a...   Oct 12 2020, 04:01 PM
Tdskip   Nice going, and thanks for the updates!   Oct 13 2020, 09:02 AM
BillC   It's finally time to take on the last "DA...   Oct 22 2020, 02:22 PM
BillC   I was able to spend some time with the car this we...   Nov 2 2020, 03:32 PM
Cairo94507   Very very nice work. :trophy:   Nov 2 2020, 04:42 PM
StarBear   Very very nice work. :trophy: :agree:   Nov 28 2020, 10:45 AM
BillC   I took advantage of the federal holiday to spend a...   Nov 11 2020, 04:17 PM
Morph914   Your thread makes me realize how fortunate I was t...   Nov 11 2020, 08:10 PM
bkrantz   Your thread makes me realize how fortunate I was ...   Nov 28 2020, 08:58 PM
BillC   I had some time yesterday to work on the car, so I...   Nov 28 2020, 10:07 AM
Superhawk996   Then, after I was finished with the mirror holes...   Nov 29 2020, 10:25 AM
BillC   Now it's time to tackle a common 914 problem (...   Nov 29 2020, 04:21 PM
Cairo94507   Chasing the rust is a very very slippery slope. I...   Nov 29 2020, 04:43 PM
BillC   So, the new sander belts came in and I got back to...   Dec 5 2020, 05:07 PM
BillC   And . . . done! It even works! I need ...   Dec 6 2020, 12:13 PM
Superhawk996   And . . . done! No getting off that easy....   Dec 21 2020, 09:01 AM
BillC   And I agree: grad school sons are sometimes helpf...   Dec 21 2020, 09:32 AM
barefoot   And . . . done! No getting off that easy...   Dec 22 2020, 12:31 PM
BillC   And, now for the moment you've all have been w...   Dec 20 2020, 05:00 PM
AZBanks   Great work. Looks really good.   Dec 20 2020, 07:01 PM
bkrantz   Looks great. And I agree: grad school sons are so...   Dec 20 2020, 09:16 PM
PanelBilly   Reading this makes me want to build another car. F...   Dec 21 2020, 12:01 AM
Cairo94507   Bill, @BillC , great job. So nice to see that do...   Dec 21 2020, 10:12 AM
bbrock   Just getting caught up on your thread. Fantastic ...   Dec 22 2020, 02:29 PM
BillC   It may look like not much has happened since the l...   Jan 10 2021, 11:43 AM
pete000   Just remember that is wasn't all that long ago...   Jan 10 2021, 03:25 PM
BillC   Time to take on the last rusty area I've found...   Jan 17 2021, 02:16 PM
BillC   I was able to spend more time today on the car, st...   Jan 18 2021, 07:27 PM
jaredmcginness   Nice work! I used 16g for that section on my c...   Jan 19 2021, 05:38 AM
46 User(s) are reading this topic (46 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th December 2024 - 08:35 PM
