What’s the Latest on LED Headlight Conversion? |
FRUNKenstein |
Dec 13 2020, 02:55 PM
Member Group: Members Posts: 109 Joined: 25-May 20 From: Overland Park, KS Member No.: 24,308 Region Association: Upper MidWest |
I’ve spent the past couple of hours searching here and surfing the web on LED headlight replacement/conversion. I see the GE Nighthawk 69821 was used by several folks, but they are expensive and no one seems to have them in stock. I think they’ve been on the market for 5+ years, so assume there are competitors. I read on a Mustang forum that the Truck-Lite 27270C is a good alternative for 7” sealed beams. I looked on Spoke’s website, but he doesn’t offer headlights, so I assume there is a good, readily-available product on the market already, or else he would have something.
So, can anybody give me an update on the latest and greatest in LED headlights? Thanks in advance! |
yellowporky |
Dec 25 2020, 06:41 PM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
So today i finally had a day off of work and was able to install the Vintage car leds.
Install was as easy as changing a light bulb since these were the simple plug and play H4 with the Hella lenses. I did notice that the spades were thinner on the led bulb and i had to squeeze the female connector down to get a solid connection. I always cringe when doing this because the old connectors are so brittle. I am very impressed with the output of the lights and the low beam cut off is very crisp compared to my old sylvania sealed bulbs. Also when i had the headlights in the up position and the battery disconnected i had pushed the switch back in one position so the headlights were off but the parking lights would all be on when i put power back. watching my voltage gauge there was no movement at all when i pulled the switch out to turn on the headlights and also no movement going from low to high beams. I would highly recommend this option Chris |
bkrantz |
Dec 25 2020, 07:47 PM
914 Guru Group: Members Posts: 7,843 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
So today i finally had a day off of work and was able to install the Vintage car leds. Install was as easy as changing a light bulb since these were the simple plug and play H4 with the Hella lenses. I did notice that the spades were thinner on the led bulb and i had to squeeze the female connector down to get a solid connection. I always cringe when doing this because the old connectors are so brittle. I am very impressed with the output of the lights and the low beam cut off is very crisp compared to my old sylvania sealed bulbs. Also when i had the headlights in the up position and the battery disconnected i had pushed the switch back in one position so the headlights were off but the parking lights would all be on when i put power back. watching my voltage gauge there was no movement at all when i pulled the switch out to turn on the headlights and also no movement going from low to high beams. I would highly recommend this option Chris Which Vintage kit or bulb did you use? |
Lo-Fi Version | Time is now: 30th June 2024 - 08:08 AM |
