djway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California ![]() |
It was suggested I make this a stand alone thread so here it is. This will work for 4 or 5 lug wheels.
Parts 07,08 cayman, 05-08 boxster 2.7L (non-S) rotors. 298x24 front 299x20 rear. Calipers 97-08 Boxster 07-08 Cayman Adapter mount for rear caliper. Re-drilled rear hub or the soon to be released 5lug hub from URO. If you want to keep 4 lug have the Boxster rotor drilled. Front hub that goes right onto the stock strut and can use 4 or 5 lug wheel. Front rotor mount adapter. I have not tried but am told 15” alloy works. Rear ![]() Front ![]() ![]() ![]() Once the URO rear hub is available (announced Nov 2020) this entire upgrade to Boxster brakes with 5 lug will be an off the shelf bolt on affair. edit I believe it can be done for both early and late struts. the struts shown are late which was harder to work out. |
preach |
Ridge Runner ![]() ![]() ![]() Group: Members Posts: 1,029 Joined: 27-March 10 From: Live Free or Die Member No.: 11,513 Region Association: North East States ![]() ![]() |
Very cool!
Lo-Fi Version | Time is now: 18th June 2024 - 05:09 AM |
