> Nuts and Bolts, Sourcing the right hardware.
Chaznaster
post Jan 3 2021, 06:54 PM
Hi All. As we dig deeper into our 914, we are finding a random assortment of nuts and bolts that I expect were incorporated into the car over the years. While I am not trying to source original hardware, I’d like to swap the odd ones out to be at more consistent (and, of course replacing any trashed/ rounded over/ damaged ones). Buying one or two at a time is going to get expensive and I cannot find a good reference for the right grade to use anyway (5.8, 8.8, 10.9, 12.9).
Is there a short list of the most common hardware found on our cars that I could use to start a collection of new ones?
Thank You!
914e
post Jan 4 2021, 01:12 AM
QUOTE(Chaznaster @ Jan 3 2021, 05:54 PM) *
Thank You!
I just happened to place an order with Belmetric, This isn't every nut bolt and screw. It is about every m5, 6, 8,10, and 12 except the engines hardware. I also have 3 German cars so there is few spares. I'm buying steel cabinets with plastic divided boxes from Bolt depot. My attempt to have an ACE hardware in my garage, plus the hardware will be the right color. I hope to cut back on my weekly runs to ACE and returning with a tiny bag of hardware that I spent $20 on.
10 x BR6X8YLW - Hex Bolt 8.8 Yellow Zinc $1.60
25 x BR6X10YLW - Hex Bolt 8.8 Yellow Zinc $4.25
25 x BR6X12YLW - Hex Bolt 8.8 Yellow Zinc $4.50
10 x BR6X14YLW - Hex Bolt 8.8 Yellow Zinc $2.30
25 x BR6X20YLW - Hex Bolt 8.8 Yellow Zinc $5.25
4 x BR6X18YLW - Hex Bolt 8.8 Yellow Zinc $0.96
4 x BR6X16YLW - Hex Bolt 8.8 Yellow Zinc $0.72
10 x BR6X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $2.30
25 x BR8X10YLW - Hex Bolt 8.8 Yellow Zinc $5.50
5 x BR8X14YLW - Hex Bolt 8.8 Yellow Zinc $1.45
20 x BR8X16YLW - Hex Bolt 8.8 Yellow Zinc $5.60
10 x BR8X20YLW - Hex Bolt 8.8 Yellow Zinc $2.90
10 x BR8X25YLW - Hex Bolt 8.8 Yellow Zinc $3.70
11 x BR8X30PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.29
10 x BR8X40PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.10
10 x BR8X45PYLW - Hex Bolt 8.8 Yellow Zinc Partial $4.50
4 x BR10X85YLW - Hex Bolt 8.8 Yellow Zinc $4.68
10 x BR10X18YLW - Hex Bolt 8.8 Yellow Zinc $4.70
10 x BR10X20YLW - Hex Bolt 8.8 Yellow Zinc $4.20
4 x BR10X22YLW - Hex Bolt 8.8 Yellow Zinc $1.88
4 x BR10X16YLW - Hex Bolt 8.8 Yellow Zinc $1.60
4 x BR10X25YLW - Hex Bolt 8.8 Yellow Zinc $1.88
4 x BR10X30YLW - Hex Bolt 8.8 Yellow Zinc $1.96
4 x BR10X35YLW - Hex Bolt 8.8 Yellow Zinc $2.24
10 x BR5X10YLW - Hex Bolt 8.8 Yellow Zinc $2.40
10 x BR5X20YLW - Hex Bolt 8.8 Yellow Zinc $2.40
4 x BR5X12YLW - Hex Bolt 8.8 Yellow Zinc $0.96
4 x BR5X22YLW - Hex Bolt 8.8 Yellow Zinc $0.96
4 x BR12X80PYLW - Hex Bolt 8.8 Yellow Zinc Partial $6.12
10 x BR12X30YLW - Hex Bolt 8.8 Yellow Zinc $7.10
4 x BR12X60PYLW - Hex Bolt 8.8 Yellow Zinc $3.56
50 x WF6YLW - Flat Washer Yellow Zinc $4.50
50 x WF8YLW - Flat Washer Yellow Zinc $6.00
20 x WF6X11YLW - Flat Washer Small OD Yellow Zinc $1.80
10 x WF8X15YLW - Flat Washer Small OD Yellow Zinc $1.20
25 x WFHV6YLW - Hardened Flat Washer Yellow Zinc $3.25
10 x WW6AMECYLW - Wave Washer Mechanical Yellow Zinc $1.20
10 x WW7BYLW - Wave Washer Yellow Zinc $2.10
10 x WSH6YLW - Schnorr Washer Yellow Zinc $1.90
10 x WSH7MECYLW- Schnorr Washer Mechanical Yellow Zinc $2.60
25 x WL5MECYLW - Lock Washer Mechanical Yellow Zinc $2.00
25 x WL6MECYLW - Lock Washer Mechanical Yellow Zinc $2.00
25 x WL8MECYLW - Lock Washer Mechanical Yellow Zinc $3.50
25 x WL10MECYLW - Lock Washer Mechanical Yellow Zinc $3.75
10 x WL12MECYLW - Lock Washer Mechanical Yellow Zinc $1.90
20 x NR6YLW - Hex Nut Yellow Zinc Class 8 $2.00
20 x NR8YLW - Hex Nut Yellow Zinc Class 8 $3.20
10 x NR10YLW - Hex Nut Yellow Zinc Class 8 $2.30
4 x NR12YLW - Hex Nut Yellow Zinc Class 8 $1.00
4 x NNFH6YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.16
4 x NNFH8YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.44
4 x NNFH10YLW - Nylock Flange Nut Yellow Zinc HARDENED $1.96
20 x E302NT - 6.3mm Uninsulated Spade 16-14 Gauge No Tab $7.00
20 x E922TABBRS - 6.3mm Uninsulated Spade 18-16 Gauge With Tab $6.80
4 x E308BRS - 6.3mm Uninsulated Male Spade With Tab 16-14 Gauge $2.04
10 x E922NTTIN - 6.3mm Uninsulated Spade 20-17 Gauge No Tab $4.00
$171.16Sub-Total:
$0.00Free Shipping Options (EXPECT DELAYS - Free Shipping):
$171.16
Chaznaster   Nuts and Bolts   Jan 3 2021, 06:54 PM
mepstein   Short answer is no list is available. First, sav...   Jan 3 2021, 07:11 PM
914 RZ-1   There happens to be a supplier of metric hardware ...   Jan 3 2021, 07:19 PM
TonyA   Auto Atlanta has or had a kit with a list of some ...   Jan 3 2021, 07:54 PM
mepstein   Auto Atlanta has or had a kit with a list of some...   Jan 3 2021, 08:29 PM
wes   Auto Atlanta has or had a kit with a list of som...   Jan 3 2021, 09:36 PM
Dave_Darling   I bought a kit many years ago with lots of DIN-spe...   Jan 3 2021, 11:30 PM
914e   Hi All. As we dig deeper into our 914, we are fin...   Jan 4 2021, 01:12 AM
zoomCat   Hi All. As we dig deeper into our 914, we are fi...   Jan 19 2023, 01:50 PM
Chaznaster   [quote name='914e' post='2880160' date='Jan 4 202...   Jan 19 2023, 07:11 PM
campbellcj   ^^^ Thanks for that list, that's awesome. I ty...   Jan 4 2021, 08:23 AM
Chaznaster   Wow! That long list is amazing! And the fi...   Jan 4 2021, 07:51 PM
Jett   Wow! That long list is amazing! And the f...   Jan 4 2021, 09:04 PM
914e   Belmetric is amazing. Fed-ex just dropped a small ...   Jan 6 2021, 01:32 PM
Root_Werks   Belmetric is amazing. Fed-ex just dropped a small...   May 4 2022, 09:24 AM
aharder   I buy most all of my fasteners from Belmetric, the...   Jan 6 2021, 02:01 PM
mepstein   I buy most all of my fasteners from Belmetric, th...   Jan 6 2021, 02:35 PM
RiqueMar   Just adding my 2-cents to the thread.... I purcha...   Jan 6 2021, 04:39 PM
bkrantz   I buy most all of my fasteners from Belmetric, t...   Jan 6 2021, 07:54 PM
RestoReese   I just learned there is a place called Belmetric. ...   Jan 6 2021, 08:55 PM
barefoot   Hi All. As we dig deeper into our 914, we are fin...   Jan 6 2021, 10:02 PM
Mikey914   We are actually putting together area specific kit...   Jan 6 2021, 11:14 PM
iankarr   Thanks @914e for this great shopping list. Super...   Jan 9 2021, 11:32 PM
mepstein   Thanks [b]@[url=http://www.914world.com/bbs2/ind...   Jan 10 2021, 07:24 AM
mlindner   Yup, Belmetric and also McMaster.   Jan 10 2021, 05:52 AM
iankarr   Good call. M10 yellow.   Jan 10 2021, 10:55 AM
914werke   resurrection: The OE case through bolts used a ...   May 3 2022, 02:36 PM
brant   resurrection: The OE case through bolts used a ...   May 4 2022, 09:34 AM
914werke   Thanks Brant I see those M8 nuts are still availab...   May 4 2022, 11:01 AM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th January 2025 - 01:35 AM
