Rebuilt 1700 CC long block, $1000 |
Al Meredith |
Jan 9 2021, 02:12 PM
Senior Member Group: Members Posts: 963 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I am about to start a 2056 and need to sell a rebuilt 1700 that is on my engine run-up stand. The pictures shows it with tin, shroud and 32/36 carb, which I would like to keep because I only use these items for run-up and test purposes . This would be a great for a substitute engine while you rebuild your own . I can arrange to help with delivery within a coulpe hundred miles of Atlanta .
B2524 |
Jan 9 2021, 03:19 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
What new parts were used in the rebuild?
Al Meredith |
Jan 11 2021, 10:13 AM
What new parts were used in the rebuild? New mains and rods , new rings ,new oil seals and gaskets. The valves were lapped and the exhaust ports were opened up , I do this to 1.7 heads because the exhaust ports don't open up to the gaskets. I do balance the pistons and the rods and on this engine I did not install the "head caskets" . If you are interested I have a direct reading oil pressure gauge installed so I can tell you the pressures and I can do a pressure test on the cylinders as well. As I remember the oil pressure was 40 PSI while cranking without plugs . AL |
Lo-Fi Version | Time is now: 26th June 2024 - 03:51 AM |
