JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
and in with.... well... MORE MEGASQUIRT!!!!
Little back story here and then a bunch of pictures. I have several 914s but the one I refer to as my "autocross car" (which started as my daily driver in the late 90s) has AFAIK been running Megasquirt possibly longer than any other 914 on the planet. For the last 17 or so years it has been the platform I have experimented on and in that time has seen at least 5 different Megasquirt configurations across 2 different motors. This ongoing project is one of the reasons I am so intimately familiar with both Megasquirt and D-jet as to date all the configurations I have ran in this particular car have done so using an unmodified d-jet wiring harness which required a good deal of study/reverse engineering. At one point my focus was on making a completely stealth setup (looks exactly like a d-jet system) which I did, however as the Megasquirt feature set improved over the last 17 years and my focus moved more towards the overall performance of the system I kept hastily hacking in additional features (mainly having to do with the addition of full ignition control and O2 feedback) and an ancillary rats nest started to grow around my once stock looking system. Remembering what all extra wires plugged in where started to become tedious, especially if I would go extended periods without doing anything to them. With the desire to change/add additional elements to the system I decided I needed to just bite the bullet and build a whole new system from the ground up. Technically i have been planning (sitting on the parts) to do this for years but as the current system ran just fine it was lower on my priority list. The whole COVID situation has allowed me lots of time to get pretty much every other project done on all my other cars, so it was time to move forward with this one. Details on the system coming out: ECU: Completely custom (see homemade) ECU board based on the MS1 2.2 circuit design however I modified the injector circuits to supply a switched current rather than a switched ground in order to work with the D-jet harness, and then later retrofitted an MS2 CPU to expand the feature set. Injectors: Stock 914 2.0 off a stock pressure regulator Ignition: Full timing control currently triggered via Pertronix pickup modified with a pullup resistor in a stock distributor with a locked out mechanical advance. Output is then from the MS system to a Mallory 6AL CD box (this was a really easy way to trigger a coil from Megasquirt back in the day as it can take a logic level input) The Goals of this project 1. Cleaning up the engine bay wiring and simplifying the connections (single harness plug to the stock relay board and thats it!) 2. Move to a 36-1 crank trigger 3. Add a 2nd MAP sensor for real time barometric correction (we have some high mountains around these parts) 4. Eliminate the distributor and CD ignition box 5. Swap the LC1 wideband controller for the newer(and smaller) LC2 6. Use a modern Fuel Injector with known voltage offset values (will get more into this later) 6.Stop using the d-jet harness (Will elaborate on this as well) WHY???!?! Back at the end of the 90s I was a d-jet purist, carbs to me have always been a step back and never an option for me, so when my d-jet system started acting up one of the things I did at the time was to purchase a new wiring harness made by a company called R.E.S. Systems. This was the only NEW replacement harness available at the time and is still an absolute work of art as far as i am concerned, overbuilt like no other d-jet harness you have ever seen. Needless to say it was not a piece I wanted to take off the car and replace with whatever homemade harness my limited experience could coble together at the time, so i invested time in figuring out how I could retrofit an MS system (also very new at the time ~2003) into an otherwise stock d-jet setup. Now, while doing this does result in a system that works as well as a good d-jet system I am here to tell everyone once and for all that D-jet does have some inherent faults with its design and that those faults become very apparent when you can see them in data logs and also when you realize that a lot of the known d-jet operational "quirks" follow you when running a modern ECU on the d-jet harness. The nicest d-jet harness in the world does not eliminate these issues, they are inherent in the design. So in the interest of having the best running car possible a new design harness is needed, which is fine by me as i want to integrate everything into a single harness anyways. Other things to come with the new build, modern 43 PSI injectors should atomize the fuel better, in addition having known voltage offset tables is mandatory to achieve the most consistant tune across all operating conditions. The change to the 36-1 crank trigger is for increased accuracy but also to improve ease of cold starts over the 4 tooth cam trigger. Getting rid of the distributor was not mandatory but I had an idea for a new setup I wanted to try out, so its getting worked in the changes as well. Had a week of vacation time to burn after Christmas that seemed like the perfect time to get this all done so... on with the show... |
JamesM |
JamesM |
and now the part that makes me sad... pulling the beautiful RES Systems D-jet harness. Almost 20 years later this thing still looks practically brand new. just a tank of a wiring harness with every connector and junction properly sealed to water proof it and every connector labeled.
If i don't wind up putting this in another car it will probably go up on my garage wall as art! ![]() ![]() |
JamesM |
New ECU is just going to be an off the shelf Microsquirt. No more 12 hours of labor custom building circuit boards for me!
I had a gutted d-jet ECU case from another one of my previous MS builds, so i re-purposed that as a bracket for the ECU, both MAP sensors and the new (much smaller) LC2 wideband controller. ![]() My old MS 2.2 custom board d-jet harness compatible ECU next to the new Microsquirt setup, not quite as trick looking but I may revisit that later. ![]() |
JamesM |
And now the REALLY fun part... putting this in there... and trying to make something out of this new mess!
![]() Laying it out as an initial test to get a rough idea of spacing from the ECU bracket to the relay board. Not looking complicated at all at this point (IMG:style_emoticons/default/biggrin.gif) ![]() Making the runs for the injectors and MAP sensors Not using pigtails for this build, everything is color coded un-spliced wires out to crimped pin connectors. Minimizing the the junctions minimizes the potential problems. NO SOLDER! ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 02:19 AM |
