JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,933 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
and in with.... well... MORE MEGASQUIRT!!!!
Little back story here and then a bunch of pictures. I have several 914s but the one I refer to as my "autocross car" (which started as my daily driver in the late 90s) has AFAIK been running Megasquirt possibly longer than any other 914 on the planet. For the last 17 or so years it has been the platform I have experimented on and in that time has seen at least 5 different Megasquirt configurations across 2 different motors. This ongoing project is one of the reasons I am so intimately familiar with both Megasquirt and D-jet as to date all the configurations I have ran in this particular car have done so using an unmodified d-jet wiring harness which required a good deal of study/reverse engineering. At one point my focus was on making a completely stealth setup (looks exactly like a d-jet system) which I did, however as the Megasquirt feature set improved over the last 17 years and my focus moved more towards the overall performance of the system I kept hastily hacking in additional features (mainly having to do with the addition of full ignition control and O2 feedback) and an ancillary rats nest started to grow around my once stock looking system. Remembering what all extra wires plugged in where started to become tedious, especially if I would go extended periods without doing anything to them. With the desire to change/add additional elements to the system I decided I needed to just bite the bullet and build a whole new system from the ground up. Technically i have been planning (sitting on the parts) to do this for years but as the current system ran just fine it was lower on my priority list. The whole COVID situation has allowed me lots of time to get pretty much every other project done on all my other cars, so it was time to move forward with this one. Details on the system coming out: ECU: Completely custom (see homemade) ECU board based on the MS1 2.2 circuit design however I modified the injector circuits to supply a switched current rather than a switched ground in order to work with the D-jet harness, and then later retrofitted an MS2 CPU to expand the feature set. Injectors: Stock 914 2.0 off a stock pressure regulator Ignition: Full timing control currently triggered via Pertronix pickup modified with a pullup resistor in a stock distributor with a locked out mechanical advance. Output is then from the MS system to a Mallory 6AL CD box (this was a really easy way to trigger a coil from Megasquirt back in the day as it can take a logic level input) The Goals of this project 1. Cleaning up the engine bay wiring and simplifying the connections (single harness plug to the stock relay board and thats it!) 2. Move to a 36-1 crank trigger 3. Add a 2nd MAP sensor for real time barometric correction (we have some high mountains around these parts) 4. Eliminate the distributor and CD ignition box 5. Swap the LC1 wideband controller for the newer(and smaller) LC2 6. Use a modern Fuel Injector with known voltage offset values (will get more into this later) 6.Stop using the d-jet harness (Will elaborate on this as well) WHY???!?! Back at the end of the 90s I was a d-jet purist, carbs to me have always been a step back and never an option for me, so when my d-jet system started acting up one of the things I did at the time was to purchase a new wiring harness made by a company called R.E.S. Systems. This was the only NEW replacement harness available at the time and is still an absolute work of art as far as i am concerned, overbuilt like no other d-jet harness you have ever seen. Needless to say it was not a piece I wanted to take off the car and replace with whatever homemade harness my limited experience could coble together at the time, so i invested time in figuring out how I could retrofit an MS system (also very new at the time ~2003) into an otherwise stock d-jet setup. Now, while doing this does result in a system that works as well as a good d-jet system I am here to tell everyone once and for all that D-jet does have some inherent faults with its design and that those faults become very apparent when you can see them in data logs and also when you realize that a lot of the known d-jet operational "quirks" follow you when running a modern ECU on the d-jet harness. The nicest d-jet harness in the world does not eliminate these issues, they are inherent in the design. So in the interest of having the best running car possible a new design harness is needed, which is fine by me as i want to integrate everything into a single harness anyways. Other things to come with the new build, modern 43 PSI injectors should atomize the fuel better, in addition having known voltage offset tables is mandatory to achieve the most consistant tune across all operating conditions. The change to the 36-1 crank trigger is for increased accuracy but also to improve ease of cold starts over the 4 tooth cam trigger. Getting rid of the distributor was not mandatory but I had an idea for a new setup I wanted to try out, so its getting worked in the changes as well. Had a week of vacation time to burn after Christmas that seemed like the perfect time to get this all done so... on with the show... |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
I agree with Jeff's premises. And of course I agree with James' as well.
Both viewpoints were part of the internal discussions I went through before Microsquirting last winter. I summarized it in my opening blog post: https://tgadrivel.blogspot.com/2020/03/on-m...914-part-1.html D-Jet was ahead of its time...in 1970. That said, there's still actually nothing "wrong" with D-Jet; it does what it needs to do, and does it quite well...as long as it's running correctly. If it is running correclty then there is absolutely no reason to replace it, as any potential efficiencies gained by "modern" fuel injection is unlikely to be recovered in fuel economy (though driveability could be improved). But when things start to go wrong, D-Jet starts to get expensive. And it's still black magic voodoo to large percentage of the 914 population, which is why many simply chuck it all and throw on carburetors. Right now we have a big hole in between the two paradigms. Our D-Jet community is in "replace it and see" mode of troubleshooting (my car is doing this, what do I replace?) Getting into an aftermarket replacement EFI system takes skills and understanding, requiring a bolt-on solution that the aftermarket cannot yet provide. The gap will narrow. I suggest our current knowledgebase on D-Jet will always remain available to those that wish to retian it, and we'll see increasing gravity toward aftermarket EFI solutions. This thread (among related others) is just one tooth in that cog. |
JamesM |
I agree with Jeff's premises. And of course I agree with James' as well. Both viewpoints were part of the internal discussions I went through before Microsquirting last winter. I summarized it in my opening blog post: https://tgadrivel.blogspot.com/2020/03/on-m...914-part-1.html D-Jet was ahead of its time...in 1970. That said, there's still actually nothing "wrong" with D-Jet; it does what it needs to do, and does it quite well...as long as it's running correctly. If it is running correclty then there is absolutely no reason to replace it, as any potential efficiencies gained by "modern" fuel injection is unlikely to be recovered in fuel economy (though driveability could be improved). But when things start to go wrong, D-Jet starts to get expensive. And it's still black magic voodoo to large percentage of the 914 population, which is why many simply chuck it all and throw on carburetors. Right now we have a big hole in between the two paradigms. Our D-Jet community is in "replace it and see" mode of troubleshooting (my car is doing this, what do I replace?) Getting into an aftermarket replacement EFI system takes skills and understanding, requiring a bolt-on solution that the aftermarket cannot yet provide. The gap will narrow. I suggest our current knowledgebase on D-Jet will always remain available to those that wish to retian it, and we'll see increasing gravity toward aftermarket EFI solutions. This thread (among related others) is just one tooth in that cog. Well said! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:14 AM |
