> Cylinder Head Temperature Sensor, 0 280 130 017 Readings
dlee6204
post Jan 16 2021, 12:07 PM
Howdy
I recently acquired a NOS temperature sensor for the one year only '73 Djet system 0 280 130 017. This sensor has been NLA for a very long time and finding a used one is very difficult. Given the rarity there isn't a lot of information on the proper resistance values of this sensor. Pbanders (https://members.rennlist.com/pbanders/DJetParts.htm) lists three data points for the resistance of this sensor but I thought I would post my findings. I also listed the values of the aftermarket sensor 0 280 130 012 available from 914Rubber.
@Superhawk996 This answers some of your concerns.
adolimpio
post Jan 23 2021, 10:37 PM
Art
There was a suggestion to add a 2400 ohm resister in parallel to the 012 to make it equivalent to the 017 at 70 degrees. I added a third line to the chart to show what that would look like. Doesn't look like a good idea - running pretty lean a low temps!
Olympic 914
post Jan 24 2021, 10:37 AM
QUOTE(adolimpio @ Jan 23 2021, 11:37 PM) *
The Cylinder Head Temps rise pretty quickly from those low temps. And from 80deg on they are pretty close. with the parallel resistor
I consider it a non-issue (JMHO)
It really depends on your engine.
I run a 1K resistor in parallel which theoretically should make my engine too lean at cold temps. But my wideband AFR tells a different story.
My engine will not idle nicely immediately upon startup. but once I drive 1 mile it is warm enough to idle (In my case, by the second Stop sign.)
One positive thing about the parallel resistor is if your CHT has a bad connection / failure, You engine will die on the spot. with the parallel resistor it will just go into a rich condition. You will still be able to drive on. I had this happen on the way home from Tennerpaluza. A little fiddling with the connection in the safety of a parking lot, instead of on the side of the road enabled me to remedy the problem and continue on.
dlee6204   Cylinder Head Temperature Sensor   Jan 16 2021, 12:07 PM
914Sixer   Maybe this should go to classics so information is...   Jan 16 2021, 12:27 PM
Superhawk996   Maybe this should go to classics so information i...   Jan 16 2021, 12:37 PM
Superhawk996   :trophy: @dlee6204 This is awesome work. You...   Jan 16 2021, 12:30 PM
Richard McLeod   I recently acquired a NOS temperature sensor for ...   Jan 16 2021, 12:30 PM
dlee6204   I recently acquired a NOS temperature sensor for...   Jan 16 2021, 12:34 PM
nordfisch   Hi, I really appreciate your work and started to t...   Jan 22 2021, 02:54 AM
Superhawk996   When I do my set up I'll extend past 212F but ...   Jan 22 2021, 06:39 AM
BillJ   Come on Hawk! Grenade your heads for us in th...   Jan 22 2021, 08:47 AM
Superhawk996   Come on Hawk! Grenade your heads for us in t...   Jan 22 2021, 08:49 AM
nordfisch   Come on Hawk! Grenade your heads for us in t...   Jan 24 2021, 10:20 AM
MM1   Thank you for posting this-think I asked this ques...   Jan 22 2021, 11:08 AM
adolimpio   There was a suggestion to add a 2400 ohm resister ...   Jan 23 2021, 10:37 PM
Olympic 914   There was a suggestion to add a 2400 ohm resister...   Jan 24 2021, 10:37 AM
914Sixer   I have a couple 003 that were superceded by the 01...   Jan 24 2021, 07:52 AM
Superhawk996   Will try to do this later today once I get tired o...   Jan 24 2021, 10:22 AM
nordfisch   Hi, my <water-cooled> engine died after 2 ml...   Jan 24 2021, 11:58 AM
Superhawk996   Measured my used 017 sensor vs. New In Bag 012 Bos...   Jan 26 2021, 07:27 AM
nordfisch   Here's my data alone 017 vs. 012 inclusive o...   Jan 26 2021, 02:26 PM
nordfisch   Hi, sorry for replying later than supposed... In ...   Jan 29 2021, 11:52 AM
Superhawk996   In the meantime I contacted Volker Huck from je...   Jan 29 2021, 05:52 PM
Superhawk996   I missed out on 8 degree F temp this morning. By ...   Jan 30 2021, 10:08 AM
Superhawk996   Just added to other thread on what the CHT resisto...   Jan 30 2021, 10:40 AM
Olympic 914   correct me if I am wrong but I see no reason, oth...   Jan 30 2021, 11:13 AM
Superhawk996   correct me if I am wrong but I see no reason, ot...   Jan 30 2021, 11:24 AM
- Lo-Fi Version Time is now: 19th March 2025 - 07:25 PM
