> Cylinder Head Temperature Sensor, 0 280 130 017 Readings
dlee6204
post Jan 16 2021, 12:07 PM
Howdy
I recently acquired a NOS temperature sensor for the one year only '73 Djet system 0 280 130 017. This sensor has been NLA for a very long time and finding a used one is very difficult. Given the rarity there isn't a lot of information on the proper resistance values of this sensor. Pbanders (https://members.rennlist.com/pbanders/DJetParts.htm) lists three data points for the resistance of this sensor but I thought I would post my findings. I also listed the values of the aftermarket sensor 0 280 130 012 available from 914Rubber.
@Superhawk996 This answers some of your concerns.
Superhawk996
post Jan 26 2021, 07:27 AM
Measured my used 017 sensor vs. New In Bag 012 Bosch sensor up to higher operating temperatures. As expected, both 017 and 012 converge to within about 10 ohms of each other at operating temperature. Remember that the 1973 only ECU setup is expecting a 270 ohm in-series resistor that would be expected in ADDITION to the 017 sensor. These measurements are of the sensor only.
Since I measured using oil up to higher temps my data set is light on temperatures below 44 degrees F. Since it's winter here in Michigan I may be able to use the weather to my advantage in the coming weeks to get some good data well below 32 F. (IMG:style_emoticons/default/dry.gif)
I measured in oil by heating on the way up and then allowing ambient cooling on the way down to get the hysteresis.
Here's my data alone 017 vs. 012 inclusive of hysteresis
And my data combined with the intial data sets from @dlee6204 to provide a second sample for a used 017 sensor and a NOS/NIB 012 Bosch sensor
Data set:
@nordfisch
nordfisch
post Jan 26 2021, 02:26 PM
QUOTE(Superhawk996 @ Jan 26 2021, 02:27 PM) *
@Superhawk996
(IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/grouphug.gif)
Thank you so much for your work!
I'll have the time to build a chart with the 'Celsius' values tomorrow.
I think the engine warms up so fast that the difference in the sensors doesn't matter much.
Yes, an engine will run up to four times richer at temperatures way below zero (Celsius) <the same as if the sensor cable is broken>, but the sensor will warm up in much less than one minute and the mixture will be in the normal range soon.
Best regards
Norbert
dlee6204   Cylinder Head Temperature Sensor   Jan 16 2021, 12:07 PM
914Sixer   Maybe this should go to classics so information is...   Jan 16 2021, 12:27 PM
Superhawk996   Maybe this should go to classics so information i...   Jan 16 2021, 12:37 PM
Superhawk996   :trophy: @dlee6204 This is awesome work. You...   Jan 16 2021, 12:30 PM
Richard McLeod   I recently acquired a NOS temperature sensor for ...   Jan 16 2021, 12:30 PM
dlee6204   I recently acquired a NOS temperature sensor for...   Jan 16 2021, 12:34 PM
nordfisch   Hi, I really appreciate your work and started to t...   Jan 22 2021, 02:54 AM
Superhawk996   When I do my set up I'll extend past 212F but ...   Jan 22 2021, 06:39 AM
BillJ   Come on Hawk! Grenade your heads for us in th...   Jan 22 2021, 08:47 AM
Superhawk996   Come on Hawk! Grenade your heads for us in t...   Jan 22 2021, 08:49 AM
nordfisch   Come on Hawk! Grenade your heads for us in t...   Jan 24 2021, 10:20 AM
MM1   Thank you for posting this-think I asked this ques...   Jan 22 2021, 11:08 AM
adolimpio   There was a suggestion to add a 2400 ohm resister ...   Jan 23 2021, 10:37 PM
Olympic 914   There was a suggestion to add a 2400 ohm resister...   Jan 24 2021, 10:37 AM
914Sixer   I have a couple 003 that were superceded by the 01...   Jan 24 2021, 07:52 AM
Superhawk996   Will try to do this later today once I get tired o...   Jan 24 2021, 10:22 AM
nordfisch   Hi, my <water-cooled> engine died after 2 ml...   Jan 24 2021, 11:58 AM
Superhawk996   Measured my used 017 sensor vs. New In Bag 012 Bos...   Jan 26 2021, 07:27 AM
nordfisch   Here's my data alone 017 vs. 012 inclusive o...   Jan 26 2021, 02:26 PM
nordfisch   Hi, sorry for replying later than supposed... In ...   Jan 29 2021, 11:52 AM
Superhawk996   In the meantime I contacted Volker Huck from je...   Jan 29 2021, 05:52 PM
Superhawk996   I missed out on 8 degree F temp this morning. By ...   Jan 30 2021, 10:08 AM
Superhawk996   Just added to other thread on what the CHT resisto...   Jan 30 2021, 10:40 AM
Olympic 914   correct me if I am wrong but I see no reason, oth...   Jan 30 2021, 11:13 AM
Superhawk996   correct me if I am wrong but I see no reason, ot...   Jan 30 2021, 11:24 AM
- Lo-Fi Version Time is now: 19th March 2025 - 07:33 PM
