> 914Rubber Rear Trailing Arm Bushings, did I get the wrong ones?
bbrock
post Jan 25 2021, 08:54 PM
@Mikey914
I bought a set of the rubber rear trailing arm bushings in the 914Rubber GB when they first came out (can't remember when that was). I am just now getting around to installing them and ran into a problem. I did a test fit to see how hard they would be to install and was shocked to find I could easily slide them into the trailing arms by hand AND could slide the pivot shaft in by hand. In fact, I'm not seeing much difference from the polygraphite bushings they are meant to replace. If anything, these fit even looser. I'm wondering I was sent the wrong ones. My understanding is the rubber bushings should be a tight fit and require a press or similar to install as seen in Ian's video. Is there a good way to know what I have? These are stamped "WDG" on the flange side which is different from the stamping on the first set of bushings I bought.
bdstone914
post Jan 26 2021, 09:28 AM
bdstone914
QUOTE(bbrock @ Jan 25 2021, 08:54 PM) *
@Mikey914
@bbrock
The problem is that the trailing arm holes can get expanded from normal use. I have installed several sets and had several sets of trailing arms in a side by side test. The bushing in one arm can be loose in another. I never liked the poly bushings and now use the rubber bushings which are more difficult to install but account for the variation on trailing arms.
Montreal914
post Jan 26 2021, 11:59 AM
QUOTE(bdstone914 @ Jan 26 2021, 07:28 AM) *
@Mikey914
@bbrock
Bruce, I believe he is using the rubber bushings not poly.
(IMG:style_emoticons/default/popcorn[1].gif) with great interest since I have this job ahead with 914 rubber bushings, refreshed trailing arms and replated stock shaft, not SS new 914 rubber.
bbrock
post Jan 26 2021, 01:00 PM
QUOTE(Montreal914 @ Jan 26 2021, 10:59 AM) *
Yep, installing rubber bushings. And yeah, the are definitely trailing arm bushings and not for the front torsion bars.
bdstone914
post Jan 26 2021, 02:29 PM
bdstone914
QUOTE(bbrock @ Jan 26 2021, 01:00 PM) *
I do not find rubber bushing listed on the 914 Rubber site. I bought these and they are definitely poly, not rubber. They give no description of the material. Is that what you bought?
The problem is that the arms get over sized holes from the leverage exerted on the bushings from cornering.
You can JB weld them into the arms.
The 914 SS shafts measure 1.105" as do the original shafts at the larger diameter. The original shafts have a .010" step. I do not know why it is there as it make the installation more difficult with rubber bushings.
Montreal914
post Jan 26 2021, 03:04 PM
QUOTE(bdstone914 @ Jan 26 2021, 12:29 PM) *
Yes, the ones on the 914Rubber screen shot are rubber per the two pictures below (IMG:style_emoticons/default/smile.gif)
Although the part number doesn't seem to match... (IMG:style_emoticons/default/idea.gif)
bbrock   914Rubber Rear Trailing Arm Bushings   Jan 25 2021, 08:54 PM
914Sixer   Sounds like the rubber shrank. Yous should not be...   Jan 25 2021, 09:39 PM
Mikey914   They are not so easy to actually install. The OD o...   Jan 25 2021, 11:14 PM
bbrock   They are not so easy to actually install. The OD ...   Jan 25 2021, 11:44 PM
BeatNavy   They are not so easy to actually install. The OD...   Jan 26 2021, 06:26 AM
Arno914   As far as I have learned, suspension rubber bushin...   Jan 26 2021, 01:49 AM
Superhawk996   Rut Roh! Could it be that you're using ...   Jan 26 2021, 06:39 AM
bbrock   Rut Roh! Could it be that you're using...   Jan 26 2021, 09:22 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 26 2021, 09:28 AM
Montreal914   [quote name='bbrock' post='2885799' date='Jan 25 ...   Jan 26 2021, 11:59 AM
bbrock   The problem is that the trailing arm holes can ...   Jan 26 2021, 01:00 PM
bdstone914   [quote name='Montreal914' post='2885952' date='Ja...   Jan 26 2021, 02:29 PM
Montreal914   [quote name='Montreal914' post='2885952' date='J...   Jan 26 2021, 03:04 PM
76-914   They're not the torsion bar bushings are they?...   Jan 26 2021, 10:28 AM
Mikey914   Very interesting, I have never been able to slide ...   Jan 26 2021, 02:40 PM
Mikey914   Yes those are mine I recognize the taper at the bo...   Jan 26 2021, 03:29 PM
bbrock   Okay, I have some pics and numbers. But first, my...   Jan 26 2021, 07:31 PM
Montreal914   I believe we have a very similar setup. My trailin...   Jan 26 2021, 08:46 PM
pete000   Well at least they were easy to install by hand wi...   Jan 26 2021, 08:52 PM
Montreal914   Well at least they were easy to install by hand w...   Jan 26 2021, 08:54 PM
76-914   :agree: that is not a good thing!   Jan 26 2021, 11:10 PM
Arno914   I believe the small step in diameter on the origin...   Jan 27 2021, 04:03 AM
bdstone914   I believe the small step in diameter on the origi...   Jan 27 2021, 06:36 AM
bbrock   Well, since it was clear the 914R bushings are not...   Feb 5 2021, 07:41 PM
914_teener   Well, since it was clear the 914R bushings are no...   Feb 6 2021, 03:13 PM
Montreal914   Thank you for sharing :trophy: There is quite ...   Feb 5 2021, 11:05 PM
bbrock   Can you share a picture of the tooling? Of cour...   Feb 6 2021, 12:05 PM
Montreal914   Very clear! :)   Feb 6 2021, 12:37 PM
Superhawk996   :cheer: I've decided to go with 85 duro RD b...   Feb 6 2021, 12:44 PM
- Lo-Fi Version Time is now: 20th April 2025 - 11:02 AM
