> 914Rubber Rear Trailing Arm Bushings, did I get the wrong ones?
bbrock
post Jan 25 2021, 08:54 PM
@Mikey914
I bought a set of the rubber rear trailing arm bushings in the 914Rubber GB when they first came out (can't remember when that was). I am just now getting around to installing them and ran into a problem. I did a test fit to see how hard they would be to install and was shocked to find I could easily slide them into the trailing arms by hand AND could slide the pivot shaft in by hand. In fact, I'm not seeing much difference from the polygraphite bushings they are meant to replace. If anything, these fit even looser. I'm wondering I was sent the wrong ones. My understanding is the rubber bushings should be a tight fit and require a press or similar to install as seen in Ian's video. Is there a good way to know what I have? These are stamped "WDG" on the flange side which is different from the stamping on the first set of bushings I bought.
Arno914
post Jan 27 2021, 04:03 AM
Region Association: Germany
I believe the small step in diameter on the original shafts is a result of cutting away and therefore smoothing the welds on an automatic lathe during production. The original rubber bushings are tight enough to compensate for those tolerances.
bbrock   914Rubber Rear Trailing Arm Bushings   Jan 25 2021, 08:54 PM
914Sixer   Sounds like the rubber shrank. Yous should not be...   Jan 25 2021, 09:39 PM
Mikey914   They are not so easy to actually install. The OD o...   Jan 25 2021, 11:14 PM
bbrock   They are not so easy to actually install. The OD ...   Jan 25 2021, 11:44 PM
BeatNavy   They are not so easy to actually install. The OD...   Jan 26 2021, 06:26 AM
Arno914   As far as I have learned, suspension rubber bushin...   Jan 26 2021, 01:49 AM
Superhawk996   Rut Roh! Could it be that you're using ...   Jan 26 2021, 06:39 AM
bbrock   Rut Roh! Could it be that you're using...   Jan 26 2021, 09:22 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 26 2021, 09:28 AM
Montreal914   [quote name='bbrock' post='2885799' date='Jan 25 ...   Jan 26 2021, 11:59 AM
bbrock   The problem is that the trailing arm holes can ...   Jan 26 2021, 01:00 PM
bdstone914   [quote name='Montreal914' post='2885952' date='Ja...   Jan 26 2021, 02:29 PM
Montreal914   [quote name='Montreal914' post='2885952' date='J...   Jan 26 2021, 03:04 PM
76-914   They're not the torsion bar bushings are they?...   Jan 26 2021, 10:28 AM
Mikey914   Very interesting, I have never been able to slide ...   Jan 26 2021, 02:40 PM
Mikey914   Yes those are mine I recognize the taper at the bo...   Jan 26 2021, 03:29 PM
bbrock   Okay, I have some pics and numbers. But first, my...   Jan 26 2021, 07:31 PM
Montreal914   I believe we have a very similar setup. My trailin...   Jan 26 2021, 08:46 PM
pete000   Well at least they were easy to install by hand wi...   Jan 26 2021, 08:52 PM
Montreal914   Well at least they were easy to install by hand w...   Jan 26 2021, 08:54 PM
76-914   :agree: that is not a good thing!   Jan 26 2021, 11:10 PM
Arno914   I believe the small step in diameter on the origin...   Jan 27 2021, 04:03 AM
bdstone914   I believe the small step in diameter on the origi...   Jan 27 2021, 06:36 AM
bbrock   Well, since it was clear the 914R bushings are not...   Feb 5 2021, 07:41 PM
914_teener   Well, since it was clear the 914R bushings are no...   Feb 6 2021, 03:13 PM
Montreal914   Thank you for sharing :trophy: There is quite ...   Feb 5 2021, 11:05 PM
bbrock   Can you share a picture of the tooling? Of cour...   Feb 6 2021, 12:05 PM
Montreal914   Very clear! :)   Feb 6 2021, 12:37 PM
Superhawk996   :cheer: I've decided to go with 85 duro RD b...   Feb 6 2021, 12:44 PM
- Lo-Fi Version Time is now: 20th April 2025 - 11:08 AM
