bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
@Mikey914
I bought a set of the rubber rear trailing arm bushings in the 914Rubber GB when they first came out (can't remember when that was). I am just now getting around to installing them and ran into a problem. I did a test fit to see how hard they would be to install and was shocked to find I could easily slide them into the trailing arms by hand AND could slide the pivot shaft in by hand. In fact, I'm not seeing much difference from the polygraphite bushings they are meant to replace. If anything, these fit even looser. I'm wondering I was sent the wrong ones. My understanding is the rubber bushings should be a tight fit and require a press or similar to install as seen in Ian's video. Is there a good way to know what I have? These are stamped "WDG" on the flange side which is different from the stamping on the first set of bushings I bought. |
Arno914 |
Member ![]() ![]() Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany ![]() ![]() |
I believe the small step in diameter on the original shafts is a result of cutting away and therefore smoothing the welds on an automatic lathe during production. The original rubber bushings are tight enough to compensate for those tolerances.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,873 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I believe the small step in diameter on the original shafts is a result of cutting away and therefore smoothing the welds on an automatic lathe during production. The original rubber bushings are tight enough to compensate for those tolerances. @arno914 I agree. Another argument as to why poly bushings are a poor material choice for trailing arm bushings. They will not contact the full surface of the original pivot shafts. |
Lo-Fi Version | Time is now: 20th April 2025 - 11:08 AM |
