> Just another home build 2056 upgrade...but this one is mine!, Redux THrÄ“: It's been so FUN lets do it again.....
rfinegan
post Jan 19 2021, 08:10 AM
Porsche 914 2056 upgrade
1.7 case upgrade from 1.7.> 2.0 now> 2056
53.9 cc (turns out these are 1.8 heads)new 2.0 style chamber with 44 x38 valves and 57 CC cambers 9.0 CR
Cam Shaft /lifters RABY 9530. See Cam Card
KB 96 Pistons and rings (2.0 rods) EMW
H-Beam rods ARP bolts. EMW
2.0 Crank.25/ Standard /.25 rods
Webber 40 and 44 carbs
Short Pierce style manifolds 3/4 bolt
Malory Unilite Grey-Grey Distributor
Pete Weber 1 5/8 4-2-1 with Evo 2 muffler Tangerine 1 5/8 stub pipes and
with 02 bung at collector
Innovate LM-1 with RPM
Balance internals
Balance Crank NEW lightened/flywheel and Pressure plate with blower
1.7 tins complete
9.0 CR with Deck height to .040
Recommend RPM range. 6200?
Est HP GOAL. 130-140 HP?
After a tear down of my 2.0l engine I started the build up to the 2056 big bore upgrade. Having a Bridgeport I started with the (5) 3/8 oil galley plug on the block halves
Drilling a hole in the plugs and a slide hammer to remove the old plugs then started the installation of the new pugs I was able to order from Type 4 store.
https://www.youtube.com/watch?v=50CYceSrBq0
https://www.youtube.com/watch?v=GOMa6nqbkBQ
rfinegan
post Jan 27 2021, 06:40 PM
Cutting 0.002 in of trimming pads of KB pistons for final weight matching lightest piston
https://www.youtube.com/watch?v=zL80ndQkf1k
barefoot
post Jan 27 2021, 06:51 PM
QUOTE(rfinegan @ Jan 27 2021, 07:40 PM) *
Cutting 0.002 in of trimming pads of FB pistons for final weight matching lightest piston
I did mine by machining an ID chamfer on the pins in the lathe. easier set-up
rfinegan   Just another home build 2056 upgrade...but this one is mine!   Jan 19 2021, 08:10 AM
rfinegan   Perhaps it is time to start a you tube channel for...   Jan 19 2021, 08:45 AM
rfinegan   Note to self: Remove bearing alignment pins prior...   Jan 19 2021, 08:52 AM
Mark Henry   Not everyone has or wants dropbox, I didn't ev...   Jan 19 2021, 09:22 AM
rfinegan   Not everyone has or wants dropbox, I didn't e...   Jan 19 2021, 09:43 AM
ddire333   Will be taking on similar soon. I know it's re...   Jan 19 2021, 10:17 AM
rfinegan   Required, I would have to say NO Best Practice. I...   Jan 19 2021, 10:31 AM
rfinegan   deleted   Jan 19 2021, 10:39 AM
rfinegan   deleted   Jan 19 2021, 10:40 AM
Superhawk996   video was too big so . . . . Post video to You...   Jan 19 2021, 12:07 PM
mepstein   We had a plug come loose while switching in a used...   Jan 19 2021, 10:41 AM
rfinegan   Looks like the PO gouged the case pulling the fron...   Jan 19 2021, 11:48 AM
rfinegan   Thanks Super hawk I added links for Youtube in OP ...   Jan 19 2021, 12:39 PM
Mark Henry   Thanks Super hawk I added links for Youtube in OP...   Jan 19 2021, 03:29 PM
rfinegan   Mark Henry, thanks for the tip on embedding , its ...   Jan 19 2021, 04:48 PM
Al Meredith   With 20/50 oil and a 30MM pump I pump about 80PSI ...   Jan 19 2021, 02:52 PM
Superhawk996   Ta da! Nice work - just like an old pro now. ...   Jan 19 2021, 05:34 PM
rfinegan   UPDATE: Just received the Engine yoke for the HF s...   Jan 25 2021, 06:50 AM
ValcoOscar   UPDATE: Just received the Engine yoke for the HF ...   Jan 26 2021, 08:22 AM
rfinegan   Woohoo..thanks Oscar UPDATE: Just received the...   Jan 26 2021, 08:24 AM
rfinegan   yoke   Jan 25 2021, 09:30 AM
VaccaRabite   Though I have built an engine on that type of yolk...   Jan 26 2021, 08:00 AM
rfinegan   Thanks for the Tip: I think I am going to use the ...   Jan 26 2021, 08:08 AM
VaccaRabite   Thanks for the Tip: I think I am going to use the...   Jan 26 2021, 08:34 AM
rfinegan   Great advice. I have an aluminum 1/2 starter ring ...   Feb 13 2021, 08:08 PM
Mark Henry   :agree: You can bend up and weld in another arm a...   Jan 26 2021, 12:24 PM
rfinegan   Today I started the engine balancing of the piston...   Jan 27 2021, 09:09 AM
Cairo94507   Very nice. :beer2:   Jan 27 2021, 01:42 PM
rfinegan   Cutting 0.002 in of trimming pads of KB pistons fo...   Jan 27 2021, 06:40 PM
barefoot   Cutting 0.002 in of trimming pads of FB pistons f...   Jan 27 2021, 06:51 PM
rfinegan   Tuning on the Piston pins is a great plan.. I deci...   Jan 27 2021, 06:57 PM
rfinegan   Final weight of trimmed KB piston.. Next up, maki...   Jan 27 2021, 06:42 PM
930cabman   I was watching this thread close, until my recent ...   Jan 27 2021, 07:23 PM
rfinegan   Today started making a test fixture for Split weig...   Jan 28 2021, 04:18 PM
barefoot   /fyrX9nuf7Ys [/quote] Nice set-up for end to end ...   Feb 5 2021, 01:25 PM
rfinegan   UPDATE: I have the internals all sorted and balan...   Feb 2 2021, 06:05 AM
rfinegan   FWIW: While waiting on the next round of parts an...   Feb 2 2021, 04:46 PM
rfinegan   Tonight I had some time to kill.... Matched b...   Feb 4 2021, 06:22 PM
rfinegan   Today: Some of my parts are arriving.... My Flyw...   Feb 5 2021, 03:08 PM
rfinegan   Fly wheel arrived from http://ljaircooledengines.c...   Feb 13 2021, 05:48 PM
rfinegan   Finished weight at just under 16 lbs. For a weight...   Feb 13 2021, 05:54 PM
rfinegan   Started trimming my 1.7 rockers for Elephant Foot...   Feb 13 2021, 05:59 PM
rfinegan   Waiting on pressure plate before I can balance the...   Feb 13 2021, 06:00 PM
BeatNavy   I hope you're enjoying the process. I enjoyed...   Feb 13 2021, 06:54 PM
rfinegan   Thanks my friend, It has been as much fun sharing ...   Feb 13 2021, 07:45 PM
rfinegan   Decided to change things up a little today. I deci...   Feb 14 2021, 01:05 PM
rfinegan   Trimming the 1.7 rockers for 911 elephant feet swi...   Feb 24 2021, 03:41 PM
VaccaRabite   I did my rockers using a bench grinder to take dow...   Feb 25 2021, 09:58 AM
rfinegan   I did my rockers using a bench grinder to take do...   Feb 25 2021, 12:21 PM
jd74914   Have to say I'm enjoying watching your progres...   Feb 25 2021, 10:53 AM
rfinegan   Tonight i decided to pull down the Old Weber 44 ID...   Mar 4 2021, 06:29 PM
rfinegan   other carb Solids are seen in both holes here too....   Mar 4 2021, 06:31 PM
rfinegan   a better shot of the plugs hole   Mar 4 2021, 06:42 PM
rfinegan   Tonight my set screw (cup points) come in M8-10x5m...   Mar 11 2021, 06:03 PM
rfinegan   This week was fabrication work: 2 1/8 exhaust pipe...   Mar 18 2021, 03:55 PM
rfinegan   another view   Mar 18 2021, 03:56 PM
rfinegan   Sound clip LhNNEG_Mi6A   Mar 18 2021, 03:57 PM
rfinegan   forgot the shot of the pipe   Mar 18 2021, 04:14 PM
rfinegan   Heads: Started life as 1.8 heads Here is a pic fro...   Mar 24 2021, 07:20 AM
rfinegan   Trying make some sense out of the balance card Loo...   Mar 24 2021, 07:24 AM
Cairo94507   @rfinegan That looks and sounds very nice. Perfe...   Mar 24 2021, 07:27 AM
rfinegan   Thank you @[url=http://www.914world.com/bbs2/ind...   Mar 24 2021, 07:40 AM
rfinegan   While waiting on my parts I started with the cam a...   Mar 25 2021, 02:05 PM
rfinegan   Tonight, I fitted the second thrust bearing in the...   Mar 26 2021, 06:48 PM
rfinegan   ARP bolt stretch: Following the instructions for ...   Mar 28 2021, 07:41 AM
Mark Henry   ARP bolt stretch: Following the instructions for...   Mar 28 2021, 09:59 AM
rfinegan   plasigage:   Mar 28 2021, 07:43 AM
rfinegan   final assemble or rods to crank: lyRqKfjtZ8Y   Mar 28 2021, 07:46 AM
ValcoOscar   final assemble or rods to crank: lyRqKfjtZ8Y ...   Mar 28 2021, 08:35 AM
rfinegan   @ValcoOscar It feels like I'm finally gettin...   Mar 28 2021, 08:37 AM
Mark Henry   BTW good work! :D   Mar 28 2021, 10:07 AM
rfinegan   Mark Henry , I did both. The first rod i did the b...   Mar 28 2021, 02:27 PM
930cabman   I know there are no dumb questions, but, I also ...   Mar 28 2021, 02:50 PM
rfinegan   Torque-to-yield fastener From Wikipedia, the free ...   Mar 28 2021, 03:34 PM
jd74914   Torque-to-yield fastener From Wikipedia, the free...   Mar 29 2021, 09:00 AM
rfinegan   Also the bolt has a shaft that is designed to stre...   Mar 28 2021, 03:39 PM
930cabman   Also the bolt has a shaft that is designed to str...   Mar 29 2021, 11:54 AM
rfinegan   @jd74914 Thanks for the feedback   Mar 29 2021, 09:17 AM
rfinegan   @930cabman :agree: about 6.99-8.99 each bolt. ...   Mar 29 2021, 11:57 AM
rfinegan   Main bearing time: ALWAYS measure your crank jour...   Mar 29 2021, 04:52 PM
rfinegan   another   Mar 29 2021, 04:53 PM
rfinegan   another pic of the worst bearing F-ed up bearing. ...   Mar 30 2021, 09:08 AM
rfinegan   another pic of the worst bearing F-ed up bearing. ...   Mar 30 2021, 09:09 AM
rfinegan   tonight cleaning bolts , H/W and intake manifolds....   Mar 30 2021, 01:46 PM
jd74914   I wish I had access to a dyno for tuning..guess ...   Apr 23 2021, 08:10 AM
rfinegan   @jd74914 I have a data logger with my O2 sensor t...   Apr 23 2021, 08:49 AM
rfinegan   Latest setbacks include: Defective Main bearing s...   Apr 21 2021, 05:54 PM
rfinegan   Last night had 2 hrs on the engine stand and have ...   Apr 23 2021, 04:38 AM
rfinegan   Sorry my last edits did not save...I Was looking a...   Apr 23 2021, 06:19 AM
Tdskip   Thanks for documenting the built and questions/les...   Apr 23 2021, 07:08 AM
rfinegan   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 23 2021, 07:14 AM
jd74914   It's a little out there, but I feel that techn...   Apr 23 2021, 10:25 AM
rfinegan   posted this on another thread for advice http://ww...   Apr 24 2021, 09:36 AM
rfinegan   Deck height measurements and compression ratio cal...   Apr 24 2021, 11:31 AM
rfinegan   Installed the pistons and cylinders tonight. The r...   Apr 24 2021, 03:08 PM
rfinegan   I am going to ty to install the piston pin retaine...   Apr 24 2021, 03:14 PM
rfinegan   Progress update: Head mock up for geometry class ...   Apr 24 2021, 03:17 PM
rfinegan   Add new valve train studs tonight and getting the ...   Apr 25 2021, 04:03 PM
rfinegan   and test springs added The test seings are from t...   Apr 27 2021, 06:21 AM
rfinegan   here is the first swing at setting the rocker geom...   Apr 27 2021, 06:23 AM
3 Pages V  1 2 3 >
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:18 PM
