Just another home build 2056 upgrade...but this one is mine!, Redux THrē: It's been so FUN lets do it again..... |
rfinegan |
Jan 19 2021, 08:10 AM
Senior Member Group: Members Posts: 1,042 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Porsche 914 2056 upgrade
1.7 case upgrade from 1.7.> 2.0 now> 2056 53.9 cc (turns out these are 1.8 heads)new 2.0 style chamber with 44 x38 valves and 57 CC cambers 9.0 CR Cam Shaft /lifters RABY 9530. See Cam Card KB 96 Pistons and rings (2.0 rods) EMW H-Beam rods ARP bolts. EMW 2.0 Crank.25/ Standard /.25 rods Webber 40 and 44 carbs Short Pierce style manifolds 3/4 bolt Malory Unilite Grey-Grey Distributor Pete Weber 1 5/8 4-2-1 with Evo 2 muffler Tangerine 1 5/8 stub pipes and with 02 bung at collector Innovate LM-1 with RPM Balance internals Balance Crank NEW lightened/flywheel and Pressure plate with blower 1.7 tins complete 9.0 CR with Deck height to .040 Recommend RPM range. 6200? Est HP GOAL. 130-140 HP? After a tear down of my 2.0l engine I started the build up to the 2056 big bore upgrade. Having a Bridgeport I started with the (5) 3/8 oil galley plug on the block halves Drilling a hole in the plugs and a slide hammer to remove the old plugs then started the installation of the new pugs I was able to order from Type 4 store. https://www.youtube.com/watch?v=50CYceSrBq0 https://www.youtube.com/watch?v=GOMa6nqbkBQ |
rfinegan |
Jan 28 2021, 04:18 PM
Today started making a test fixture for Split weight connecting rod measurements .Big end , small end ,and gross weight. Big + small = Gross If we have no loss in the set up ( easy enough to check)
I purchased my Rods from http://www.europeanmotorworks.com/pvw/024-...0%22+-+Set+of+4 after preliminary testing they seem good out of the box (only weighed the Big ends so far) The gross weight on the rods seem to be within +- 1 Gram on a kitchen scale (mine scale goes t o. 500 grams with a resolution of 0.01 grams) so I had to borrow my "cheff" son's scale Big ends weight : 1)251.62 g 2)251.56 g 3)251.30 g 4)251.40 g Small ends weight: 1)177.87 g 2)177.65 g 3)177.41 g 4)177.44 g The ARP bolts seem to be with .07 grams of each other https://www.youtube.com/watch?v=/fyrX9nuf7Ys |
barefoot |
Feb 5 2021, 01:25 PM
Senior Member Group: Members Posts: 1,336 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
https://www.youtube.com/watch?v=/fyrX9nuf7Ys [/quote] Nice set-up for end to end balancing.! (IMG:style_emoticons/default/beer.gif) I tried using a much less sophisticated technique and gave up as i couldn't repeat results, just did overall rod weight balance |
Lo-Fi Version | Time is now: 6th January 2025 - 08:37 PM |
