bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
@Mikey914
I bought a set of the rubber rear trailing arm bushings in the 914Rubber GB when they first came out (can't remember when that was). I am just now getting around to installing them and ran into a problem. I did a test fit to see how hard they would be to install and was shocked to find I could easily slide them into the trailing arms by hand AND could slide the pivot shaft in by hand. In fact, I'm not seeing much difference from the polygraphite bushings they are meant to replace. If anything, these fit even looser. I'm wondering I was sent the wrong ones. My understanding is the rubber bushings should be a tight fit and require a press or similar to install as seen in Ian's video. Is there a good way to know what I have? These are stamped "WDG" on the flange side which is different from the stamping on the first set of bushings I bought. |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,809 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Thank you for sharing (IMG:style_emoticons/default/smilie_pokal.gif)
There is quite a difference in diameters (ID and OD) between the 3 candidates (IMG:style_emoticons/default/blink.gif) and a substantial increase in the interference fit for the Elephant Racing bushing! (IMG:style_emoticons/default/ohmy.gif) It will be interesting to compare the dimensions with @bdstone914 bushing's coming from Restoration Design EU. (IMG:style_emoticons/default/idea.gif) Can you share a picture of the tooling? |
Lo-Fi Version | Time is now: 20th April 2025 - 11:00 AM |
