raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
I've got a 71 914-4 that I converted to a 914-6.
The problem is a very loud annoying squeak when I'm in the R-1st plane. Something is really scraping badly. Pulled the shifter which looks to have been changed out from an early shifter to a later shifter. Greased it very well and that didn't seem to help. So I looked a bit deeper and put a flashlight in the tunnel where the shifter sits pointing backwards. Using a small mirror about 6-9" rearward, I see that the shift rod goes through a circular opening in a small bulkhead that is welded into the tunnel. Looks like the scraping/squeaking is when the rod is hitting the edge of the circular opening in the bulkhead in the R-1st plane. If you don't pull the lever all the way to the left, then you don't hear the scrape. Is this typical of a side shifter conversion for an early 914? Am I shifting incorrectly by pulling the lever hard to the left for the R-1st plane? Does that bulkhead need to be removed by opening up the shift tunnel from above? Any thoughts or ideas are welcome. Thanks in advance. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Wont a jigsaw blade come close to the metal tubes?
What about a die grinder with a small cutting disk? |
raynekat |
Wont a jigsaw blade come close to the metal tubes? What about a die grinder with a small cutting disk? Yeah, I'll likely try that. Certainly don't want to cut anything valuable inside the tunnel. I'll be looking a lot inside with my mirror as I go. Should be quite doable. Will happen this weekend. The scraping while shifting is driving me crazy on this car. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,955 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Wont a jigsaw blade come close to the metal tubes? What about a die grinder with a small cutting disk? Yeah, I'll likely try that. Certainly don't want to cut anything valuable inside the tunnel. I'll be looking a lot inside with my mirror as I go. Should be quite doable. Will happen this weekend. The scraping while shifting is driving me crazy on this car. @raynekat I'll tell you from experience that there is only 2-3 mm of clearance between the floorpan and these control tubes near that bracket. Be careful in there I have a picture of that are in sideview in my build thread. ![]() Thin grey on bottom is floorpan edge view. Closest tube is the clutch cable tube, the smaller one behind it is the throttle cable tube and there is only 2-3mm clearance to the floorpan. If you cut a hatch flap, it needs to be biased toward the passenger side to avoid the tubes. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:30 AM |
