Question for the gear shift experts: big scrap in R-1st shift plane on side shifter |
raynekat |
Feb 3 2021, 07:07 PM
Advanced Member Group: Members Posts: 2,162 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I've got a 71 914-4 that I converted to a 914-6.
The problem is a very loud annoying squeak when I'm in the R-1st plane. Something is really scraping badly. Pulled the shifter which looks to have been changed out from an early shifter to a later shifter. Greased it very well and that didn't seem to help. So I looked a bit deeper and put a flashlight in the tunnel where the shifter sits pointing backwards. Using a small mirror about 6-9" rearward, I see that the shift rod goes through a circular opening in a small bulkhead that is welded into the tunnel. Looks like the scraping/squeaking is when the rod is hitting the edge of the circular opening in the bulkhead in the R-1st plane. If you don't pull the lever all the way to the left, then you don't hear the scrape. Is this typical of a side shifter conversion for an early 914? Am I shifting incorrectly by pulling the lever hard to the left for the R-1st plane? Does that bulkhead need to be removed by opening up the shift tunnel from above? Any thoughts or ideas are welcome. Thanks in advance. |
gereed75 |
Feb 6 2021, 09:50 AM
Senior Member Group: Members Posts: 1,310 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
My original six with side shifter did this. From memory it went away once I refurbished the shifter with a Weltmiester short shifter and Tangerine firewall bushing.
Never realized this clearance hole was different in early cars vs side shifters and how lucky I was that this worked itself out. Now wondering what will happen as stuff wears. At least I will know what it is The other thought I had was that you could maybe cut the shift rod in this area and weld a smaller diameter section into it at this area. Lotsa work, but maybe no more than accessing the tunnel to clearance the hole. |
ChrisFoley |
Feb 6 2021, 11:06 AM
I am Tangerine Racing Group: Members Posts: 7,964 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Never realized this clearance hole was different in early cars vs side shifters and how lucky I was that this worked itself out. I'm not sure the hole is any different. The early shift rod was a larger diameter but was supported by bushings at both ends so it only rotated and moved fore/aft. The sideshift rod moves left and right at the shift lever so requires more room around it. |
Lo-Fi Version | Time is now: 25th November 2024 - 11:41 AM |
