raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
I've got a 71 914-4 that I converted to a 914-6.
The problem is a very loud annoying squeak when I'm in the R-1st plane. Something is really scraping badly. Pulled the shifter which looks to have been changed out from an early shifter to a later shifter. Greased it very well and that didn't seem to help. So I looked a bit deeper and put a flashlight in the tunnel where the shifter sits pointing backwards. Using a small mirror about 6-9" rearward, I see that the shift rod goes through a circular opening in a small bulkhead that is welded into the tunnel. Looks like the scraping/squeaking is when the rod is hitting the edge of the circular opening in the bulkhead in the R-1st plane. If you don't pull the lever all the way to the left, then you don't hear the scrape. Is this typical of a side shifter conversion for an early 914? Am I shifting incorrectly by pulling the lever hard to the left for the R-1st plane? Does that bulkhead need to be removed by opening up the shift tunnel from above? Any thoughts or ideas are welcome. Thanks in advance. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,843 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
@rayneKat - Excellent photos and work. Looking forward to the end result. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 20th June 2024 - 05:45 AM |
