raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
I've got a 71 914-4 that I converted to a 914-6.
The problem is a very loud annoying squeak when I'm in the R-1st plane. Something is really scraping badly. Pulled the shifter which looks to have been changed out from an early shifter to a later shifter. Greased it very well and that didn't seem to help. So I looked a bit deeper and put a flashlight in the tunnel where the shifter sits pointing backwards. Using a small mirror about 6-9" rearward, I see that the shift rod goes through a circular opening in a small bulkhead that is welded into the tunnel. Looks like the scraping/squeaking is when the rod is hitting the edge of the circular opening in the bulkhead in the R-1st plane. If you don't pull the lever all the way to the left, then you don't hear the scrape. Is this typical of a side shifter conversion for an early 914? Am I shifting incorrectly by pulling the lever hard to the left for the R-1st plane? Does that bulkhead need to be removed by opening up the shift tunnel from above? Any thoughts or ideas are welcome. Thanks in advance. |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,827 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Doug, just a thought. How much bigger/wider do you need the hole to be? Could you do that by forcing a wedge into the hole (with the rod removed)? I can imagine a wedge attached to a 1/2 inch rod long enough to stick out through the fire wall. And then hit with a hammer? Or some other way to pry the hole wider?
Might not need to cut a hatch in the tunnel. (Oops, I just noticed the second page of the thread and your documentation of the job done. Maybe next time.) |
Lo-Fi Version | Time is now: 20th June 2024 - 05:52 AM |
