Question for the gear shift experts: big scrap in R-1st shift plane on side shifter |
raynekat |
Feb 3 2021, 07:07 PM
Advanced Member Group: Members Posts: 2,160 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I've got a 71 914-4 that I converted to a 914-6.
The problem is a very loud annoying squeak when I'm in the R-1st plane. Something is really scraping badly. Pulled the shifter which looks to have been changed out from an early shifter to a later shifter. Greased it very well and that didn't seem to help. So I looked a bit deeper and put a flashlight in the tunnel where the shifter sits pointing backwards. Using a small mirror about 6-9" rearward, I see that the shift rod goes through a circular opening in a small bulkhead that is welded into the tunnel. Looks like the scraping/squeaking is when the rod is hitting the edge of the circular opening in the bulkhead in the R-1st plane. If you don't pull the lever all the way to the left, then you don't hear the scrape. Is this typical of a side shifter conversion for an early 914? Am I shifting incorrectly by pulling the lever hard to the left for the R-1st plane? Does that bulkhead need to be removed by opening up the shift tunnel from above? Any thoughts or ideas are welcome. Thanks in advance. |
PlaysWithCars |
Feb 7 2021, 08:41 PM
Senior Member Group: Members Posts: 528 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
@bdstone914
Honestly I'm not sure if my car uses a late model front rod or a modified early rod. I do know that it has the late style connection to the shifter and fits into the conversion bushing at the firewall. But what's in between (IMG:style_emoticons/default/confused24.gif). Seems like a lot of work to modify the front and the back and keep the middle for no apparent value. So I'm going to guess that its a late rod. |
Lo-Fi Version | Time is now: 21st September 2024 - 06:47 PM |
