DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I have been dealing with this for 12 years, a non-running defrost fan. i even pulled this out 2 years ago and rebuilt it with new flapper seals and main body seal then made sure fan turned but didnt bench test the motor or resisitors, so as a result it still does not work properly. i will be documenting this because 914rubber and Mark will soon be putting together a kit for this that includes all the hardware seals and even a motor i believe, BUT i still have problems and questions!!! so i am starting this thread to get information on diagnosing the common causes of it not working and how to fix it, and then document the rebuild and replacement of the motor, fan, resistor and maybe the control unit in dash. Others have documented the reinstallation of the fan and the cables so i will not duplicate that. and we may want to link other threads hear that have done that as well.
Mark is sending me a kit soon, so while i wait for it, i will have to get some more information about the wiring and resistors function and how to test them . I had this out last week and tested 3 different control units due to thinking that my issue was a control issue, because it runs on one speed, #2, and anything else does not work and it will then throw the fuse. most assume this would be caused by bad slider unit but i tested 3 of them and 2 are like new with no wear on the sliders , still same result. so i am suspecting the resistors /plug aparatus . If anyone has done this and cares to share how to examine and test that for proper function, lets start there. Resistor function, which lead is which and examination of the control units I will take pictures of mine tonight and post those soon. once this figured out and fixed i will do a full step bystep on reassembly too. Looking for lots of help and input on this, thanks!!! Dr. Phil |
DRPHIL914 |
@Mikey914
@Superhawk996 here is my first batch of hardware and seals from 914rubber!! now the fun can begin- i will need a second set of stuff to do the other box, but i am going to install a brand new fan into one unit, and a known good oem one in the other. both need all new seals and will have a nice clean and restored fan housing (lowered half) i need a replacement top half if anyone has a mint one please PM me it’s the late type with the screen, the air/ water diverter part. tonight i will do one rebuild and post the pics of the during and after . - first pic is of the fan seal no one makes until now! all the ones i have opened had these seals in very poor shape, it’s a porous seal not solid like the new 914rubber seal. Thanks again Mark and Matt! Attached thumbnail(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 05:41 AM |
