> Fuel Injection, Reinstall advice
shane
post Jan 25 2021, 07:54 AM
The PO had a single carb on when I bought my 74’ 1.8 914 and said he had uneven idle problems with the L-jet injection so he preceded to remove all components and box everything up. So now I’m feeling I want to reinstall the injection and put it back to stock. I have some mechanical ability and patience, though I was never able to get that gas smelling carb to run right. Was looking for someone I could pay for a few hours to kinda orientate me on the location of the box of injection parts I have and give me thoughts on what parts I might be missing and how difficult and expensive it will be to put everything back. I’m in Puyallup WA south hill area, Thanks In advance
timothy_nd28
post Feb 13 2021, 11:23 PM
Not a bad thing to do. Sometimes these cold start valves leak and will cause a rich running condition. Your box of Ljet parts looks beautiful, but it is concerning that is was removed for some reason. So it would be wise to be proactive with checking most everything before bolting these unknown parts back on.
I haven't followed your previous posts, are you building a concours mint 914? Have you already replaced the plastic fuel lines in the tunnel? This may be argumentative to many, but I would ditch the 3 port fuel pump, and relocate the new fuel pump up front.
shane
post Feb 14 2021, 01:23 AM
QUOTE(timothy_nd28 @ Feb 13 2021, 09:23 PM) *
Definitely not concours but keeping everything as stock as I can. Was thinking about getting the 2 port but not sure about relocating it to the front yet. A quick test on the FI harness showed a bad wire and more then a few brittle and cracked. I’m betting the PO was fighting that maybe. The hoses on the injectors are new but did notice not much of a bend on them. Was mainly looking for info on what is directly beneath the plenum so I can buy those parts and get started with the installation soon. Thanks
shane   Fuel Injection   Jan 25 2021, 07:54 AM
914werke   Shane there is a character & longtime member i...   Jan 25 2021, 10:16 AM
shane   Shane there is a character & longtime member ...   Jan 25 2021, 10:36 AM
ClayPerrine   The PO had a single carb on when I bought my 74â€...   Jan 25 2021, 11:15 AM
shane   The PO had a single carb on when I bought my 74â...   Jan 25 2021, 12:13 PM
shane   The PO had a single carb on when I bought my 74â...   Jan 25 2021, 04:45 PM
914werke   HERE   Jan 25 2021, 11:17 AM
shane   HERE Thanks   Jan 25 2021, 04:42 PM
shane   and a decent fuel injection harness   Jan 25 2021, 04:47 PM
Porschef   Might be something as simple as cracks in the back...   Jan 25 2021, 05:52 PM
shane   Might be something as simple as cracks in the bac...   Jan 25 2021, 06:29 PM
ndfrigi   [quote name='Porschef' post='2885719' date='Jan 2...   Jan 25 2021, 06:33 PM
914werke   At first glance looks to be pretty complete. I don...   Jan 25 2021, 06:34 PM
wonkipop   i encourage you to do it. its a primal system. f...   Jan 26 2021, 12:51 AM
nihil44   Another reply from down under Go with the L Jet. ...   Jan 26 2021, 02:53 AM
nordfisch   i encourage you to do it. its a primal system. ...   Jan 29 2021, 07:42 AM
wonkipop   [quote name='wonkipop' post='2885843' date='Jan 2...   Jan 29 2021, 06:17 PM
nordfisch   [quote name='nordfisch' post='2886718' date='Jan ...   Jan 31 2021, 02:19 PM
wonkipop   [quote name='nordfisch' post='2886718' date='Jan...   Feb 1 2021, 03:33 AM
Porschef   Does look very complete, the dual relay is present...   Jan 26 2021, 05:19 AM
ClayPerrine   There is a thread on here to convert an L-Jet syst...   Jan 26 2021, 08:34 AM
JeffBowlsby   You will need both the L-Jet FI harness and L-Jet ...   Jan 26 2021, 10:33 AM
rhodyguy   The new harnesses would be the hot ticket. For the...   Jan 26 2021, 10:51 AM
ClayPerrine   For the injectors, Witch Hunter services them and...   Jan 26 2021, 03:36 PM
wonkipop   For the injectors, Witch Hunter services them an...   Jan 27 2021, 02:28 AM
rhodyguy   What do those cost each? If the stock core injecto...   Jan 26 2021, 04:13 PM
ClayPerrine   What do those cost each? If the stock core inject...   Jan 26 2021, 10:03 PM
Mcraneiowa   There is so much knowledge on here, these guys wil...   Jan 26 2021, 08:51 PM
shane   There is so much knowledge on here, these guys wi...   Jan 27 2021, 07:55 AM
djway   Have you looked at the potentiometer board under t...   Jan 27 2021, 12:13 AM
ClayPerrine   Let me know what pictures you need. The engine wi...   Jan 27 2021, 09:11 AM
shane   Let me know what pictures you need. The engine w...   Jan 27 2021, 01:25 PM
ndfrigi   Let me know what pictures you need. The engine ...   Jan 27 2021, 01:34 PM
shane   I’m thinking this part? in the picture had a cov...   Jan 27 2021, 03:40 PM
ClayPerrine   I’m thinking this part? in the picture had a co...   Jan 28 2021, 05:51 AM
shane   I’m thinking this part? in the picture had a c...   Jan 28 2021, 07:34 AM
wonkipop   think what you call thermo time sensor would be th...   Jan 28 2021, 04:59 PM
914werke   That is not part of any L-Jet system I have ever...   Jan 28 2021, 05:25 PM
Mcraneiowa   Hopefully this gives you some idea of the step...   Jan 29 2021, 07:45 PM
shane   Hopefully this gives you some idea of the ste...   Jan 29 2021, 08:23 PM
wonkipop   nice images of a beautiful build mr. m. can see t...   Jan 29 2021, 08:22 PM
shane   I definitely have to powder coat my plenum silver ...   Jan 29 2021, 08:28 PM
wonkipop   that is your air cleaner bracket. mounts off the ...   Jan 29 2021, 10:05 PM
914werke   that is your air cleaner bracket. mounts off the...   Jan 30 2021, 12:30 AM
Mcraneiowa   You should be able to set your parts in same areas...   Jan 30 2021, 08:36 PM
shane   Received my injectors back, the hoses are pretty s...   Feb 13 2021, 07:09 PM
ClayPerrine   Received my injectors back, the hoses are pretty ...   Feb 14 2021, 06:37 AM
timothy_nd28   I'm pretty sure it was engine case, plenum the...   Feb 13 2021, 08:21 PM
shane   Thanks, good luck with your project   Feb 13 2021, 08:40 PM
timothy_nd28   Hey Shane, curious if you sent all 5 injectors to ...   Feb 13 2021, 09:29 PM
shane   Hey Shane, curious if you sent all 5 injectors to...   Feb 13 2021, 10:40 PM
timothy_nd28   Not a bad thing to do. Sometimes these cold start ...   Feb 13 2021, 11:23 PM
shane   Not a bad thing to do. Sometimes these cold start...   Feb 14 2021, 01:23 AM
timothy_nd28   I'm actually in the process of making a few re...   Feb 14 2021, 09:48 PM
wonkipop   the injector hoses literally support the fuel rail...   Feb 15 2021, 02:23 AM
shane   the injector hoses literally support the fuel rai...   Feb 15 2021, 07:36 AM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 04:56 PM
