hcdmueller |
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England ![]() ![]() |
I am in the middle of moving to the UK. The Air Force has already picked up all of our stuff. 2 days ago I tried to start my car and no luck. It's a 76 and after relacing or troubleshooting everything, it's still not starting. I bit the bullet and bought a vacuum pump from Harbor Freight to check out the MPS. It isn't a complete fail, but it leaks down from 20 to 14 lbs in < 4 min.
List if things I've done. New vacuum lines, rubber intake sleeves, injector seals, fuel filter, spark plugs, head temp sensor. Checked fuel pressure, injector function, TPS adjustment. I have the 123ignition distributor with new cap and rotor. I have to ship this car in 10 days or less. Obviously it needs to be running. Does anyone have a known good 2.0 compatible MPS I could borrow/rent/purchase right now? I'm in Panama City, FL. Given the weather, something closer to me would probably be better. Other options could be a good running set of carbs and intakes or if someone has a plug n play microsquirt setup sitting on the shelf. Any help is appreciated. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
A blown MPS usually means pig rich trying to start up like chug chug cough sputter....
Is it firing at all? |
Lo-Fi Version | Time is now: 26th June 2024 - 12:13 AM |
