Speedo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains ![]() ![]() |
Installing my steering rack in my 6 and noticed that there is a decent size hole were the shaft comes through the firewall. Looked on PET and it shows item #32 is a gasket that looks to go over the top of the shaft before the shaft connects to the U-joint under the dash. 914 rubber doesn't look like they carry that. My son's 1.7 is missing it, and Brant's car is missing it too. I have some chunks of open cell foam which I could probably use to make something that would seal the area around the shaft. Thoughts? Ignore it? If I am going to do something about it...now is the time before I tap the U-joint over the splines and bolt it together.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Installing my steering rack in my 6 and noticed that there is a decent size hole were the shaft comes through the firewall. Looked on PET and it shows item #32 is a gasket that looks to go over the top of the shaft before the shaft connects to the U-joint under the dash. 914 rubber doesn't look like they carry that. My son's 1.7 is missing it, and Brant's car is missing it too. I have some chunks of open cell foam which I could probably use to make something that would seal the area around the shaft. Thoughts? Ignore it? If I am going to do something about it...now is the time before I tap the U-joint over the splines and bolt it together. I have one. It is a plastic collar that fits to the angle at which the shaft enters the cabin. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:03 AM |
