> Idle hunting, Where do I start?
steuspeed
post Mar 16 2021, 07:24 PM
I'm working on fixing my idle search. All new vacuum lines, plugs and wires. Car starts and runs smooth for about 1-2minutes, then the idle dumps and starts hunting up and down. My ECU knob was turned full clockwise by the PO. I turned it back to the factory setting.
Stock 2.0L 1973 car with Pertronix. Where should I look next?
cary
post Mar 17 2021, 11:01 PM
Concur with Rob & Rich, too lean.
steuspeed   Idle hunting   Mar 16 2021, 07:24 PM
Bleyseng   Do you have the resistor installed?   Mar 16 2021, 11:36 PM
steuspeed   I see a white wire/connector/black wire to cylinde...   Mar 17 2021, 04:59 PM
rjames   Are you sure no vacuum leaks? Does changing the po...   Mar 17 2021, 01:14 AM
steuspeed   Are you sure no vacuum leaks? Does changing the p...   Mar 17 2021, 05:17 PM
wonkipop   not sure i can help as have a 1.8 L jet. but have ...   Mar 17 2021, 01:24 AM
BeatNavy   I think you're running lean. You need to trou...   Mar 17 2021, 05:50 PM
steuspeed   I think you're running lean. You need to tro...   Mar 18 2021, 03:36 PM
914werke   :agree: hunting idle is usually a symptom of lean ...   Mar 17 2021, 06:09 PM
steuspeed   :agree: hunting idle is usually a symptom of lean...   Mar 18 2021, 12:09 AM
mgphoto   Most times it’s the idle screw on the throttle b...   Mar 17 2021, 09:44 PM
steuspeed   Most times it’s the idle screw on the throttle ...   Mar 18 2021, 12:10 AM
cary   Concur with Rob & Rich, too lean.   Mar 17 2021, 11:01 PM
BeatNavy   I wouldn't worry too much about the idle bypas...   Mar 18 2021, 05:18 AM
steuspeed   I wouldn't worry too much about the idle bypa...   Mar 18 2021, 03:38 PM
saigon71   Agreed that you are running lean at idle. Start...   Mar 19 2021, 05:33 AM
JamesM   Agreed that you are running lean at idle. Star...   Mar 19 2021, 08:45 AM
rjames   Agreed that you are running lean at idle. Sta...   Mar 19 2021, 11:39 AM
914_7T3   My ‘73 had the same symptoms and it was indeed t...   Mar 19 2021, 01:28 PM
- Lo-Fi Version Time is now: 22nd December 2024 - 11:18 AM
