> Idle hunting, Where do I start?
steuspeed
post Mar 16 2021, 07:24 PM
I'm working on fixing my idle search. All new vacuum lines, plugs and wires. Car starts and runs smooth for about 1-2minutes, then the idle dumps and starts hunting up and down. My ECU knob was turned full clockwise by the PO. I turned it back to the factory setting.
Stock 2.0L 1973 car with Pertronix. Where should I look next?
BeatNavy
post Mar 18 2021, 05:18 AM
I wouldn't worry too much about the idle bypass screw at this point. You can try adjusting it to see what happens, but if you are lean it isn't going to have that much impact. That's actually another symptom of a lean idle condition -- idle bypass not having much impact on idle speed.
Confirm you are running lean and then figure out why.
Again, any symptoms under driving conditions, or only idle?
steuspeed
post Mar 18 2021, 03:38 PM
QUOTE(BeatNavy @ Mar 18 2021, 04:18 AM) *
The idle screw is working well. I can dial up any idle I choose. I found 1500-1800 cold on another thread.
steuspeed   Idle hunting   Mar 16 2021, 07:24 PM
Bleyseng   Do you have the resistor installed?   Mar 16 2021, 11:36 PM
steuspeed   I see a white wire/connector/black wire to cylinde...   Mar 17 2021, 04:59 PM
rjames   Are you sure no vacuum leaks? Does changing the po...   Mar 17 2021, 01:14 AM
steuspeed   Are you sure no vacuum leaks? Does changing the p...   Mar 17 2021, 05:17 PM
wonkipop   not sure i can help as have a 1.8 L jet. but have ...   Mar 17 2021, 01:24 AM
BeatNavy   I think you're running lean. You need to trou...   Mar 17 2021, 05:50 PM
steuspeed   I think you're running lean. You need to tro...   Mar 18 2021, 03:36 PM
914werke   :agree: hunting idle is usually a symptom of lean ...   Mar 17 2021, 06:09 PM
steuspeed   :agree: hunting idle is usually a symptom of lean...   Mar 18 2021, 12:09 AM
mgphoto   Most times it’s the idle screw on the throttle b...   Mar 17 2021, 09:44 PM
steuspeed   Most times it’s the idle screw on the throttle ...   Mar 18 2021, 12:10 AM
cary   Concur with Rob & Rich, too lean.   Mar 17 2021, 11:01 PM
BeatNavy   I wouldn't worry too much about the idle bypas...   Mar 18 2021, 05:18 AM
steuspeed   I wouldn't worry too much about the idle bypa...   Mar 18 2021, 03:38 PM
saigon71   Agreed that you are running lean at idle. Start...   Mar 19 2021, 05:33 AM
JamesM   Agreed that you are running lean at idle. Star...   Mar 19 2021, 08:45 AM
rjames   Agreed that you are running lean at idle. Sta...   Mar 19 2021, 11:39 AM
914_7T3   My ‘73 had the same symptoms and it was indeed t...   Mar 19 2021, 01:28 PM
- Lo-Fi Version Time is now: 22nd December 2024 - 11:07 AM
