Car Llift, Park 2 Cars and work under them |
stickyfingers |
Mar 22 2021, 07:47 AM
Member Group: Members Posts: 168 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
mskala |
Mar 22 2021, 11:23 AM
R Group: Members Posts: 1,927 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I have a 4-post that serves a similar purpose but does get in the way more.
I think I've seen the single post type that has the base piece (floor) extend the same distance as the lift fork. Personally I would be more comfortable with that than the one you have that 100% relies on the bolts in the floor. |
stickyfingers |
Mar 22 2021, 11:32 AM
I have a 4-post that serves a similar purpose but does get in the way more. I think I've seen the single post type that has the base piece (floor) extend the same distance as the lift fork. Personally I would be more comfortable with that than the one you have that 100% relies on the bolts in the floor. It's counter-lever so there is a base that extended about mid-way. The lift is rated for 6000lb and I had it professionally installed. That's exactly it, I get complete unfettered access to the vehicles from the sides and the bottom. There is a 10-yr warranty on the lift and 3-year for labour. The company is reputable and has done many installs without any issues. Also these bolts practically go 1/2 ft into the ground and there are about 20 I would say. It is a marvel of engineering. |
Lo-Fi Version | Time is now: 27th December 2024 - 10:48 AM |
