Just another home build 2056 upgrade...but this one is mine!, Redux THrē: It's been so FUN lets do it again..... |
rfinegan |
Jan 19 2021, 08:10 AM
Senior Member Group: Members Posts: 1,042 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Porsche 914 2056 upgrade
1.7 case upgrade from 1.7.> 2.0 now> 2056 53.9 cc (turns out these are 1.8 heads)new 2.0 style chamber with 44 x38 valves and 57 CC cambers 9.0 CR Cam Shaft /lifters RABY 9530. See Cam Card KB 96 Pistons and rings (2.0 rods) EMW H-Beam rods ARP bolts. EMW 2.0 Crank.25/ Standard /.25 rods Webber 40 and 44 carbs Short Pierce style manifolds 3/4 bolt Malory Unilite Grey-Grey Distributor Pete Weber 1 5/8 4-2-1 with Evo 2 muffler Tangerine 1 5/8 stub pipes and with 02 bung at collector Innovate LM-1 with RPM Balance internals Balance Crank NEW lightened/flywheel and Pressure plate with blower 1.7 tins complete 9.0 CR with Deck height to .040 Recommend RPM range. 6200? Est HP GOAL. 130-140 HP? After a tear down of my 2.0l engine I started the build up to the 2056 big bore upgrade. Having a Bridgeport I started with the (5) 3/8 oil galley plug on the block halves Drilling a hole in the plugs and a slide hammer to remove the old plugs then started the installation of the new pugs I was able to order from Type 4 store. https://www.youtube.com/watch?v=50CYceSrBq0 https://www.youtube.com/watch?v=GOMa6nqbkBQ |
rfinegan |
Mar 30 2021, 01:46 PM
tonight cleaning bolts , H/W and intake manifolds......
I had several intakes to choose from, but decided I'm am running the short manifolds and the larger opening for the weber 44. This thing is going to breath! 6k should be pulling good with the Raby web cam 9530. Else, I can put the 40 IDFs and the longer intakes and try for some torque. I wish I had access to a dyno for tuning..guess it will be seat of the pants or how white my wife's knuckles turn? https://www.youtube.com/watch?v=ClGIBygT0VM |
Lo-Fi Version | Time is now: 6th January 2025 - 08:36 PM |
