Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
timothy_nd28 |
Feb 17 2021, 11:40 AM
strawman |
Apr 2 2021, 11:41 AM
Senior Member Group: Members Posts: 883 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I sent a message yesterday to the folks at GoWesty (their "campus" is located about 0.5 miles from my house!) to see how their TPS could be adapted to work with our L-Jet system. I'll provide an update as soon as I hear back. |
ClayPerrine |
Apr 2 2021, 12:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I sent a message yesterday to the folks at GoWesty (their "campus" is located about 0.5 miles from my house!) to see how their TPS could be adapted to work with our L-Jet system. I'll provide an update as soon as I hear back. The L-Jet is a throttle switch, not a TPS. So a TPS fitted to it won't work. You would have to put the original L-Jet switch on it. Clay |
Lo-Fi Version | Time is now: 25th September 2024 - 10:45 PM |
