> Repairing Engine Tin, A newbie's lesson in welding - second side
seanpaulmc
post Feb 22 2021, 07:20 PM
I recommend all new welders to get some 50 year old thin gage sheet metal to learn with. (IMG:style_emoticons/default/welder.gif) How hard could it be?
In doing so, you’ll practice with voltage and wire speed, stick out, part set up, metal cleaning, contamination and porosity, work area lighting, youtube, weld grinding, fabrication, clamping, gapping, blow thru, backing materials, warping, patience and wire brushing, to name a few.
What I have...
How many cracks can you spot?
Save your original OG engine tin they say. It's the best they say.
So after a few hours...
I'm not kidding anyone here with these pictures, after many days I find myself with this...
I have several questions for those with at least a few hours more experience.
1) How much more, if any, should these welds be ground down? Or, will the weld beads provide future strength to the thin, stretched sheet metal so leave as-is?
2) In order of preference, what would be the best three tools to use to grind down welds on thin sheet metal? Assume you don't have an air compressor. I don't.
3) For the top section where the coil attaches on the tin, the coil bracket uses P/N: N 010 210 13 which is M 6 x 10 hex-head bolt. Is the tin supposed to have a captured nut on the backside or just thicker sheet metal in the locations that are missing on my tin (see first few pictures).
4) Should the coil mounting location be relocated in order to avoid whatever the hell happened here? If so, where?
In actuality I'm quite please with the results so far, maybe not the pace of the work, but at least the product thus far. It'll be useable tin and certainly better than it was. (IMG:style_emoticons/default/screwy.gif) This is literally the first time I have ever fabricated a patch and tried to weld anything. I'm working my way up to the easy stuff if there such a thing?
I appreciate you entertaining my questions.
Thanks,
Sean
wonkipop
post Apr 9 2021, 04:09 AM
mate
you are a hero for working out how to do this.
fortunately i do not own one with a coil screwed down on the tins.
which german kook thought that was a good idea?
and those guys are the masters of metal?
(you know the germans have some kind of perverse respect for the brits?)
the japs would never have made that mistake.
thousands of years making swords.
but good old american know how to sort it.
(mind you same know how also screwed the cars, but would be the same here).
seanpaulmc   Repairing Engine Tin   Feb 22 2021, 07:20 PM
Archie   I recommend all new welders to get some 50 year o...   Feb 22 2021, 07:54 PM
cary   3" 36gr RoLoc on a 2" pad. Gives you a f...   Feb 22 2021, 08:34 PM
malcolm2   Paint 'em and drive it.   Feb 22 2021, 10:51 PM
rfinegan   I just spent a few hours on mine last night. And ...   Feb 23 2021, 04:51 AM
Mark Henry   Take a section of copper sheet or copper pipe and ...   Feb 23 2021, 08:26 AM
Archie   Take a section of copper sheet or copper pipe and...   Feb 23 2021, 07:21 PM
Mark Henry   Take a section of copper sheet or copper pipe an...   Feb 24 2021, 08:56 AM
ClayPerrine   [quote name='Archie' post='2894103' date='Feb 23 ...   Apr 8 2021, 11:17 AM
76-914   [quote name='Archie' post='2894103' date='Feb 23 ...   May 8 2021, 04:26 PM
Robarabian   Yes on the copper. Also, where you see the nice ri...   Feb 24 2021, 09:09 AM
rfinegan   Got this a Harbor Freight for a few bucks....   Feb 24 2021, 09:26 AM
dr914@autoatlanta.com   the passenger side 2.0 engine cylinder cover is im...   Feb 24 2021, 10:09 AM
Mark Henry   the passenger side 2.0 engine cylinder cover is i...   Feb 24 2021, 10:46 AM
Superhawk996   Like this one? BTW I have the other side as wel...   Feb 25 2021, 06:58 AM
Mark Henry   [quote name='Mark Henry' post='2894247' date='Feb...   Feb 25 2021, 08:41 AM
Superhawk996   The dies used to pop these pieces out were quite...   Feb 25 2021, 09:31 AM
Shivers   The dies used to pop these pieces out were quit...   Apr 8 2021, 10:05 AM
Jett   Like this one? BTW I have the other side as we...   Feb 25 2021, 09:10 AM
Superhawk996   [quote name='Mark Henry' post='2894247' date='Feb...   Feb 25 2021, 09:51 AM
Jett   [quote name='Mark Henry' post='2894247' date='Fe...   Feb 25 2021, 12:31 PM
914_teener   the passenger side 2.0 engine cylinder cover is ...   Feb 25 2021, 09:26 AM
Bleyseng   [quote name='Mark Henry' post='2894247' date='Feb...   Apr 7 2021, 08:20 PM
seanpaulmc   Hello Mark Henry - Could you scoot that tin arou...   Apr 7 2021, 06:06 PM
Mark Henry   Hello Mark Henry - Could you scoot that tin aro...   Apr 8 2021, 09:32 AM
bkrantz   For grinding welds on sheet metal I like flappy sa...   Feb 24 2021, 10:02 PM
bbrock   For grinding welds on sheet metal I like flappy s...   Feb 25 2021, 08:37 AM
bbrock   I never thought about it before but that right fro...   Feb 25 2021, 08:49 AM
VaccaRabite   What I want to know is - what on earth caused thos...   Feb 25 2021, 09:52 AM
Superhawk996   What I want to know is - what on earth caused tho...   Feb 25 2021, 09:58 AM
Mark Henry   What I want to know is - what on earth caused tho...   Feb 25 2021, 10:01 AM
914sgofast2   What I want to know is - what on earth caused th...   Apr 7 2021, 06:52 PM
seanpaulmc   The area of concern I have for this piece of tin i...   Apr 8 2021, 11:42 AM
Mark Henry   The tin is correct in that area, you're good t...   Apr 8 2021, 11:45 AM
wonkipop   mate you are a hero for working out how to do thi...   Apr 9 2021, 04:09 AM
930cabman   mate you are a hero for working out how to do th...   Apr 9 2021, 05:01 AM
seanpaulmc   Finally got back to finishing up the tin repair. ...   Apr 19 2021, 06:41 AM
seanpaulmc   When taking the Tin off the engine, I have this sm...   Apr 19 2021, 06:51 AM
seanpaulmc   Are the heat control boxes salvageable? Thank...   Apr 19 2021, 06:57 AM
Mark Henry   Are the heat control boxes salvageable? Than...   Apr 19 2021, 07:40 AM
930cabman   Great job, can I send a couple of mine in for repa...   Apr 20 2021, 07:00 AM
seanpaulmc   Great job, can I send a couple of mine in for rep...   Apr 21 2021, 05:07 PM
930cabman   [quote name='930cabman' post='2909442' date='Apr ...   Apr 21 2021, 05:12 PM
Arno914   Any "normal" 914 was long rusted to piec...   Apr 20 2021, 08:37 AM
seanpaulmc   Moving onto the other side... This is the main to...   Apr 21 2021, 05:19 PM
930cabman   Moving onto the other side... This is the main t...   May 8 2021, 03:33 PM
seanpaulmc   Bump for questions about the 1-2 tin. How much do...   Apr 23 2021, 11:39 AM
dirk2056   Can someone post pictures of what profile the tins...   May 8 2021, 10:52 AM
seanpaulmc   I truly appreciate all the tips and support on wel...   May 8 2022, 05:18 PM
Mark Henry   I truly appreciate all the tips and support on we...   May 8 2022, 05:48 PM
21 User(s) are reading this topic (21 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 12:41 PM
