Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
If all goes as planned, I should be swapping out my stock old distributor for a brand new Mallory distributor running a CDI box in the next few weeks. In the past this was not possible since the trigger points for the FI are located in the base of the D-Jet distributor....on my work bench, I have come up with a bolt-on solution that should cost no more than about $35 that will fit inside of a Mallory Unilite distributor.....I do not have an MSD distributor, but I'd imagine the same type of unit could be installed fairly easily.
just thought I'd see if I am the only crazy person wanting to upgrade/change their ignition? (legal mod for local Bp cars, you must keep the stock FI, but no limit on the ignition) |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
absolutely, anything beats a kilobuck for a spankin new OE distributor
Lo-Fi Version | Time is now: 30th June 2024 - 01:04 PM |
