Just another home build 2056 upgrade...but this one is mine!, Redux THrē: It's been so FUN lets do it again..... |
rfinegan |
Jan 19 2021, 08:10 AM
Senior Member Group: Members Posts: 1,042 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Porsche 914 2056 upgrade
1.7 case upgrade from 1.7.> 2.0 now> 2056 53.9 cc (turns out these are 1.8 heads)new 2.0 style chamber with 44 x38 valves and 57 CC cambers 9.0 CR Cam Shaft /lifters RABY 9530. See Cam Card KB 96 Pistons and rings (2.0 rods) EMW H-Beam rods ARP bolts. EMW 2.0 Crank.25/ Standard /.25 rods Webber 40 and 44 carbs Short Pierce style manifolds 3/4 bolt Malory Unilite Grey-Grey Distributor Pete Weber 1 5/8 4-2-1 with Evo 2 muffler Tangerine 1 5/8 stub pipes and with 02 bung at collector Innovate LM-1 with RPM Balance internals Balance Crank NEW lightened/flywheel and Pressure plate with blower 1.7 tins complete 9.0 CR with Deck height to .040 Recommend RPM range. 6200? Est HP GOAL. 130-140 HP? After a tear down of my 2.0l engine I started the build up to the 2056 big bore upgrade. Having a Bridgeport I started with the (5) 3/8 oil galley plug on the block halves Drilling a hole in the plugs and a slide hammer to remove the old plugs then started the installation of the new pugs I was able to order from Type 4 store. https://www.youtube.com/watch?v=50CYceSrBq0 https://www.youtube.com/watch?v=GOMa6nqbkBQ |
rfinegan |
Apr 24 2021, 09:36 AM
posted this on another thread for advice
http://www.914world.com/bbs2/index.php?showtopic=353010 Hi World, I added the shims to my 2056 I took out of the engine to get a base line. Same crank and shims but new bearings. So cleaned the shims and installed new Flywheel WO seal and clean shims. tight or just right? Do I hose the lube out with brake clean( dry bearing)? https://www.youtube.com/watch?v=QiM03KJbUhk This does not look right...Thanks for the feed back Mark Henry, and Ian Karr. I now have the familiar clunk when moving the crank...see new video for details https://www.youtube.com/watch?v=vdgSpxFqe9s I now get .004 endplay with not prying and I think it is a little assembly lube still on the crank/thrust, So I think i am now in the Sweet Spot! Woohoo -Best Robert |
Lo-Fi Version | Time is now: 6th January 2025 - 08:21 PM |
