Just another home build 2056 upgrade...but this one is mine!, Redux THrē: It's been so FUN lets do it again..... |
rfinegan |
Jan 19 2021, 08:10 AM
Senior Member Group: Members Posts: 1,042 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Porsche 914 2056 upgrade
1.7 case upgrade from 1.7.> 2.0 now> 2056 53.9 cc (turns out these are 1.8 heads)new 2.0 style chamber with 44 x38 valves and 57 CC cambers 9.0 CR Cam Shaft /lifters RABY 9530. See Cam Card KB 96 Pistons and rings (2.0 rods) EMW H-Beam rods ARP bolts. EMW 2.0 Crank.25/ Standard /.25 rods Webber 40 and 44 carbs Short Pierce style manifolds 3/4 bolt Malory Unilite Grey-Grey Distributor Pete Weber 1 5/8 4-2-1 with Evo 2 muffler Tangerine 1 5/8 stub pipes and with 02 bung at collector Innovate LM-1 with RPM Balance internals Balance Crank NEW lightened/flywheel and Pressure plate with blower 1.7 tins complete 9.0 CR with Deck height to .040 Recommend RPM range. 6200? Est HP GOAL. 130-140 HP? After a tear down of my 2.0l engine I started the build up to the 2056 big bore upgrade. Having a Bridgeport I started with the (5) 3/8 oil galley plug on the block halves Drilling a hole in the plugs and a slide hammer to remove the old plugs then started the installation of the new pugs I was able to order from Type 4 store. https://www.youtube.com/watch?v=50CYceSrBq0 https://www.youtube.com/watch?v=GOMa6nqbkBQ |
rfinegan |
Apr 24 2021, 03:08 PM
Installed the pistons and cylinders tonight. The rings I fitted prior and was uneventful
top ring=025 second ring (dot) = 015 oil control=015 Clocked and numbered each and started the piston pins retainers to keep thing going. Only one was the wrong side and had to swap (or piston upside down?) NOPE! Heated the small end with a heat gun and 10 mins for the pin in the freezer make the pins slide in EZ https://www.youtube.com/watch?v=DjbJC5wjhLE |
Lo-Fi Version | Time is now: 6th January 2025 - 08:21 PM |
