crank shaft end play, Lots of assembly lube on trust bearing (NEED ADVICE) |
rfinegan |
Apr 24 2021, 09:33 AM
Senior Member Group: Members Posts: 1,043 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Hi World,
I added the shims to my 2056 I took out of the engine to get a base line. Same crank and shims but new bearings. So cleaned the shims and installed new Flywheel WO seal and clean shims. tight or just right? Do I hose the lube out with brake clean( dry bearing)? https://www.youtube.com/watch?v=QiM03KJbUhk Please advise -Best Robert |
Mark Henry |
Apr 24 2021, 03:41 PM
I use the feeler gauge type, I found it's just as accurate. I use two shims, measure and do the math. I then add the third shim and RMS. Don't forget the flywheel O-ring, pilot bearing, felt washer (seal) and a new large lock washer.
Once done I do one last check, so to me the lube doesn't make a difference when measuring. Pro tip use an old lock washer when measuring your end play so the bolts don't mark the flywheel. |
Lo-Fi Version | Time is now: 9th January 2025 - 09:02 AM |
