Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I'm repairing the battery tray and related hot spot. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
I need your tech advice on the procedure. I want to first make paper templates and then fit the sheet metal. Maybe hang it with rivets or screws before the big weld off. Stock look is not important to me. Just needs to drain and support the new battery tray and pedestal. I will sand off the remaining surface rust before applying rust converting primer. I'm scratching the naval jelly approach. Also, please post pics of your repaired areas. Here's my project. Thanks, as usual! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) KT Attached image(s) ![]() |
DJsRepS |
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 ![]() |
This is a great Form good post AirSix I just did all that but mine was not as bad. Should the surrounding metal be treated with the osphos treatment before welding ? Good or bad? I was concerned about inhaleing the welding fumes from the treated metal.
