> Tracking the 914 - Need some street love too..., Turning this into a regular thing...
infraredcalvin
post Oct 24 2019, 06:08 PM
Distracted Member
1st track day in the bag with the new 914, no decent pics yet (there was a photog in attendants, but haven’t seen his pics yet). Car rand great and although running with much newer machinery she was holding her own once her driver brushed off the cobwebs... (IMG:style_emoticons/default/driving.gif)
Since this was essentially her first shakedown I found a number of little things I need to address, one in particular I’m questioning:
After a few laps I noticed - mainly on a flat sweeper turn, when entering hard on brakes and trailing off while turning in I’d get a soft groan from my outside wheel (drivers in this case). I’m thinking wheel bearing? I’ve never had one go bad on the front spindle before, so I’ve never heard or felt the slight vibration before. Never really occurred on any other turns.... thoughts?
infraredcalvin
post Apr 11 2021, 08:56 PM
Distracted Member
https://www.youtube.com/watch?v=JZiq93JBxTY
I was able to tune most of the popping and hacking out, but on three of the 6, idle mixture had no effect, time to start taking apart and cleaning out...
Justinp71
post May 2 2021, 11:22 PM
QUOTE(infraredcalvin @ Apr 11 2021, 07:56 PM) *
Start with just cleaning the idle jets if you haven't already... Then if needed pull out the idle mixture screws (with idle jets out) and blow out with carb cleaner.
infraredcalvin   Tracking the 914 - Need some street love too...   Oct 24 2019, 06:08 PM
wndsrfr   First thing that comes to mind is "You could ...   Oct 24 2019, 08:05 PM
914 Ranch   When I turn in right my front left tire touches th...   Oct 24 2019, 10:09 PM
infraredcalvin   Ha, car is loud, 44 webber’s and headers, it doe...   Oct 24 2019, 11:28 PM
infraredcalvin   Took a hard look, couldn’t see any rubbing, auto...   Oct 25 2019, 07:44 PM
infraredcalvin   Photo credit: @garyambrose1256   Nov 3 2019, 09:56 AM
Charles Freeborn   Wheel bearings usually make noise under lateral lo...   Nov 5 2019, 04:55 PM
infraredcalvin   Thanks! As far as brakes and pads, I’ve got...   Nov 6 2019, 01:59 PM
2mAn   I recognize that car, I nearly bought it myself bu...   Nov 6 2019, 05:48 PM
infraredcalvin   I recognize that car, I nearly bought it myself b...   Nov 6 2019, 10:16 PM
infraredcalvin   October autocross with POC, nothing too eventful, ...   Nov 18 2019, 11:34 PM
infraredcalvin   Nov autocross, I’m starting to get hooked... def...   Nov 18 2019, 11:51 PM
infraredcalvin   Back to the track! Entered the PDS group of P...   Feb 25 2020, 12:15 AM
infraredcalvin   Made it in to the POC mag Velocity, helps when the...   Feb 27 2020, 10:39 PM
dr.tim   Fast spot in the outside of 8, a spooky place to s...   Mar 3 2020, 04:01 PM
ThePaintedMan   :Qarl: Looks like you're having fun. I have to...   Mar 4 2020, 05:32 AM
GregAmy   I have never done the 5-2 but used to miss shifts ...   Mar 4 2020, 07:32 AM
Charles Freeborn   I have never done the 5-2 but used to miss shifts...   Mar 6 2020, 10:46 AM
infraredcalvin   I wa s looking at the tangerine kit. The PO did s...   Mar 5 2020, 10:24 AM
campbellcj   It's cool to see a 914 out with POC, a fairly ...   Mar 8 2020, 12:56 PM
infraredcalvin   Spent last weekend at WSIR again, here’s 1 lap, ...   May 20 2020, 12:00 AM
infraredcalvin   Car ran well in the AM, not so much in the heat, ...   May 20 2020, 12:08 AM
campbellcj   Very cool, sounds like a fun time - I hope to join...   May 20 2020, 07:23 AM
infraredcalvin   That would be awesome! Hopefully in your teen...   May 20 2020, 07:53 AM
infraredcalvin   Had 1/2 of a great weekend despite the heat. Was ...   Sep 10 2020, 12:53 AM
infraredcalvin   Skipped the race in Pahrump... onto Chuckwalla...   Nov 9 2020, 10:55 PM
GregAmy   What are we looking at? What went kablooey? The T...   Nov 10 2020, 07:50 AM
wndsrfr   Go 2270 or 2316 (96mmx80mm stroker) for about 1/5 ...   Nov 10 2020, 11:05 AM
infraredcalvin   Go 2270 or 2316 (96mmx80mm stroker) for about 1/5...   Nov 10 2020, 09:17 PM
infraredcalvin   *But be careful: more power = more speed = I nee...   Nov 10 2020, 08:53 PM
GregAmy   He did such a nice job I don’t want to go down t...   Nov 10 2020, 09:12 PM
GregAmy   The pic is of all the oil coming from the top of ...   Nov 10 2020, 09:23 PM
infraredcalvin   Wow, I hope so! What are your thoughts on 72i...   Nov 10 2020, 10:12 PM
infraredcalvin   Sorry I missed your post, I think the gal showed m...   Nov 10 2020, 10:30 PM
GregAmy   No thoughts on the oil pressure. Greater than zero...   Nov 10 2020, 10:32 PM
infraredcalvin   Well, no such luck on the damage. I dropped the m...   Nov 17 2020, 09:12 AM
mepstein   Holy moly   Nov 17 2020, 09:14 AM
brant   those "windows" in the case are a clear ...   Nov 17 2020, 09:39 AM
GregAmy   Ooooowww.... "So what happened?" ...   Nov 17 2020, 12:13 PM
campbellcj   ^^^ So this is basically why I went -6 after nerv...   Nov 18 2020, 08:55 AM
Racer   Re. POC it's gotten depressing how few older ...   Nov 18 2020, 09:39 AM
infraredcalvin   Just got off the phone with Dennis at FAT, looks l...   Nov 18 2020, 02:45 PM
Tdskip   @infraredcalvin - ouch. Sorry to see it man, ouc...   Nov 18 2020, 04:05 PM
Charles Freeborn   Ooooohh.... that hurts... Did it destroy the crank...   Nov 19 2020, 12:45 PM
GregAmy   Ooooohh.... that hurts... Did it destroy the cran...   Nov 19 2020, 04:23 PM
wndsrfr   Ooooohh.... that hurts... Did it destroy the cra...   Nov 19 2020, 08:25 PM
rhodyguy   FAT was the deal back in the Hot VW&Dune Buggy...   Dec 2 2020, 09:29 PM
infraredcalvin   Yup, the old FAT was next to my dads work growing ...   Dec 4 2020, 11:32 PM
infraredcalvin   UPDATE: Motor build is progressing fine, ultimate...   Feb 3 2021, 09:03 AM
yeahmag   What dry sump pump will you be running? I've b...   Feb 3 2021, 11:53 AM
infraredcalvin   Sorry, I thought I had a picture of the clean pump...   Feb 3 2021, 01:16 PM
infraredcalvin   Also used modified tuna can on bottom. Only conce...   Feb 3 2021, 01:18 PM
yeahmag   Looks like a BugPack pump. Did you happen to recor...   Feb 3 2021, 04:56 PM
infraredcalvin   Looks like a BugPack pump. Did you happen to reco...   Feb 3 2021, 07:18 PM
ChrisFoley   Autocraft Dry Sump Pump.   Feb 3 2021, 06:23 PM
infraredcalvin   BTW, the valve head broke off, no dropped seat. P...   Feb 3 2021, 07:26 PM
Tdskip   Thanks for the updates - sounds like you have a go...   Feb 4 2021, 08:27 AM
infraredcalvin   Thanks for the updates - sounds like you have a g...   Feb 4 2021, 10:32 AM
Tdskip   Thanks for the updates - sounds like you have a ...   Feb 4 2021, 10:36 AM
infraredcalvin   The 914 gods were on my side and I finally picked ...   Feb 6 2021, 08:38 PM
sixnotfour   Nice Upgrade !!!   Feb 7 2021, 01:10 PM
Charles Freeborn   Sweet! If you'd be interested in selling ...   Feb 17 2021, 11:18 AM
infraredcalvin   Sweet! If you'd be interested in selling...   Feb 18 2021, 12:29 AM
ndfrigi   Congrats on your new beast @infraredcalvin Maybe...   Feb 18 2021, 12:58 AM
infraredcalvin   Thanks, I’d like to, but I’m still trying to g...   Feb 18 2021, 08:13 AM
infraredcalvin   Who would have thought spark plugs would be on bac...   Mar 17 2021, 03:08 PM
Tdskip   Score!   Mar 19 2021, 10:51 AM
Justinp71   Nice Motor! What are the specs on it (size, ca...   Mar 22 2021, 09:56 AM
infraredcalvin   Motor came with limited info, but finding notes re...   Mar 23 2021, 08:12 AM
slivel   Motor came with limited info, but finding notes r...   Mar 27 2021, 11:45 AM
Tdskip   I have 964 cams in the ‘74 911 with the 3.2, the...   Mar 23 2021, 09:47 AM
campbellcj   Wow congrats, that looks like a lot of fun!   Mar 27 2021, 08:07 AM
infraredcalvin   Got motor back in, everything hooked up, 6 qts of ...   Apr 10 2021, 10:15 PM
Charles Freeborn   Got motor back in, everything hooked up, 6 qts of...   Apr 11 2021, 07:02 PM
infraredcalvin   JZiq93JBxTY I was able to tune most of the poppin...   Apr 11 2021, 08:56 PM
Justinp71   JZiq93JBxTY I was able to tune most of the poppi...   May 2 2021, 11:22 PM
infraredcalvin   Still have the 4, finally got my new FAT build bac...   May 1 2021, 10:15 PM
infraredcalvin   Thanks, I ended up, rebuilding the carbs, glad I d...   May 2 2021, 11:56 PM
Justinp71   Fyi, they run rich all the time. This is so the tr...   May 4 2021, 02:17 PM
Justinp71   Also I'd just drive it to the raceway... much ...   May 4 2021, 04:26 PM
infraredcalvin   I’m hearing you about running rich. I’m still...   May 4 2021, 11:58 PM
Justinp71   Wow, 10:1 at WOT that is rich, got some power on t...   May 6 2021, 04:13 PM
Charles Freeborn   Wow, 10:1 at WOT that is rich, got some power on ...   May 8 2021, 08:48 AM
infraredcalvin   No videos or real pics, but Willow Spring's wa...   May 18 2021, 02:51 PM
infraredcalvin   Arrived at track!   May 18 2021, 10:55 PM
Justinp71   Nice! I'm sure you'll be knocking the ...   May 21 2021, 05:52 PM
infraredcalvin   Right now engine tune is my highest priority, yes ...   May 22 2021, 11:04 AM
wndsrfr   Right now engine tune is my highest priority, yes...   May 22 2021, 02:20 PM
infraredcalvin   Gotta pin down front of hood. PO put spacers a...   May 22 2021, 11:20 AM
stownsen914   Gotta pin down front of hood. PO put spacers at...   May 23 2021, 08:11 AM
stownsen914   On the engine tune, AFRs around 10 is way rich. Fo...   May 23 2021, 08:30 AM
infraredcalvin   air may be flowing IN there instead of out. This ...   May 23 2021, 10:12 AM
stownsen914   It's a little hard to figure out the orientati...   May 23 2021, 11:53 AM
infraredcalvin   I had the RE71s on my old car (205/50/15) loved th...   May 22 2021, 07:49 PM
infraredcalvin   Yeah sorry for the pic, imaging standing on the ga...   May 23 2021, 03:47 PM
infraredcalvin   I feel like the PO did his reading, bought a bunch...   May 23 2021, 03:51 PM
Justinp71   I agree may have something fundamentally wrong. Ch...   May 24 2021, 03:30 PM
infraredcalvin   @stownsen914 I never answered your question about...   May 27 2021, 11:16 AM
wndsrfr   Air filters are K&Ns with a flat rain shiel...   May 27 2021, 07:17 PM
infraredcalvin   Air filters are K&Ns with a flat rain shie...   May 27 2021, 09:04 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 3rd April 2025 - 01:26 AM
