I had a dream, It was about a 6 |
DavidSweden |
May 8 2021, 10:37 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I had a dream to install a 6, that was a few years back and I even got a 2,2T motor but the project didn't get off the ground, anyway as I have run out of things to do I thought I might resurrect the idea.
According to the PO the motor came out of a running car and I want to make sure that it runs before I commit to installing it. What do I need to do to get it running? I do not have a spare gearbox for the starter or an oil tank is there an easy way to fire it up without (or using substitutes for) these parts and what about the electrics, there is a coil but I think I need more than that? Any help much appreciated as I know nothing about these engines. PS: It looks like the motor has been opened up at some time there is a lot of sealer on the case seam behind the flywheel, do you think its been opened? |
infraredcalvin |
May 9 2021, 01:15 AM
Distracted Member Group: Members Posts: 1,575 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Set valves
Perform a leak down Rebuild carbs If all check out, install and get it running in the car. |
Lo-Fi Version | Time is now: 27th December 2024 - 07:52 PM |
