Idle control and maybe intake leaks, how to for swapping in a 52mm Vanagon throttle body |
VaccaRabite |
Apr 25 2021, 12:53 PM
En Garde! Group: Admin Posts: 13,615 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I broke the plug to my idle control valve. I bought a new plug housing. Easy. But I’ve had a devil of a time finding the right socket pins for the housing. Several weeks have been stalled waiting for 80 cents worth of pins that show up and are the wrong size. So, knowing the 914 has to drive next weekend, I went full DACO and soldered a pigtail of wires into the ICV and then crimped them into place. About to find out if it works, and will continue to work for a couple weeks while I sleuth out the right sockets for the plug Wish me luck! Zach |
Montreal914 |
May 9 2021, 11:47 AM
Senior Member Group: Members Posts: 1,725 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Zack, really cool writeup! Thank you for sharing. (IMG:style_emoticons/default/smile.gif)
There is some information on Shoptalkforums about the use of the 1.7 or bus plenum with the 2.0 runners and the 2.0 heads. I believe some have used this kind of setup on 2256 (2270) size engines too. In your case, what is your plenum, runner, and head setup? Thanks! |
VaccaRabite |
May 9 2021, 06:14 PM
Zack, really cool writeup! Thank you for sharing. (IMG:style_emoticons/default/smile.gif) In your case, what is your plenum, runner, and head setup? Thanks! A mishmash. The engine is using a Bus case, 1.7 heads which have been bored out. A friend was getting rid of an entire 1.8 Ljet system so I took it for the parts (this engine used to be carbed). So my airbox, plenum and runners are 1.8. I removed the flapper box from the 1.8 and replaced it with some exhaust pipe that was the right size and put a bung in that for the ambient air temp sensor. The 52mm throttle body is the same outside dimensions as the stock LJet unit so everything fit back together perfectly. Zach |
Lo-Fi Version | Time is now: 21st December 2024 - 08:53 PM |
