Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I'm repairing the battery tray and related hot spot. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
I need your tech advice on the procedure. I want to first make paper templates and then fit the sheet metal. Maybe hang it with rivets or screws before the big weld off. Stock look is not important to me. Just needs to drain and support the new battery tray and pedestal. I will sand off the remaining surface rust before applying rust converting primer. I'm scratching the naval jelly approach. Also, please post pics of your repaired areas. Here's my project. Thanks, as usual! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) KT Attached image(s) ![]() |
Trekkor |
Good things are happening (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Used the grinder and wire wheel to remove most of the surface rust. Attached image(s) ![]() |
