DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I have thought about this a few times and forget to ask if this matters, . do we just not worry about that extra quart or so that is in the cooler and cooler lines, OR option 2 drain it or 3. run it after changing it, long enought to open the thermostat that allows for the oil to circulate thru the cooler and run it for a while and then change it again?
seems we are only getting about 3/4 of the oil out and changed if i leave it in there- my motor is a stock 2.0 and the cooler was installed at Tangerine racing, it is small one that comes off an adaptor plate on the oil filter location. thanks for the input. Phil |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Live with it, just change the oil at least once a year.
Also it's less oil than you think. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:03 AM |
