DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I have thought about this a few times and forget to ask if this matters, . do we just not worry about that extra quart or so that is in the cooler and cooler lines, OR option 2 drain it or 3. run it after changing it, long enought to open the thermostat that allows for the oil to circulate thru the cooler and run it for a while and then change it again?
seems we are only getting about 3/4 of the oil out and changed if i leave it in there- my motor is a stock 2.0 and the cooler was installed at Tangerine racing, it is small one that comes off an adaptor plate on the oil filter location. thanks for the input. Phil |
DRPHIL914 |
On a related note - how do you properly fill a system with a dry cooler? The thermostat will be closed on a front mounted cooler so how do you get oil into that part of the system so the level doesn’t drop when the thermostat actually opens? On a related note - how do you properly fill a system with a dry cooler? The thermostat will be closed on a front mounted cooler so how do you get oil into that part of the system so the level doesn’t drop when the thermostat actually opens? I put some oil in the cooler before attaching the lines. My lines enter at the top so it was easy. I don’t think anyone really worries about getting the old oil out of coolers on all the modem cars. Like superhawk said, it’s very little volume. @Tdskip i think this is why when i go to Valvoline for example for my truck, they run it for a while then recheck and top off? then turn it off and recheck level and show you your level too - so that they can make sure a vehicle with an oil cooler has that oil circulating and levels are good. i dont tknow but seems plausible @mepstein @superhawk996 @Mark Henry thanks for the responses, i figured i was overthinking it, and will just change it like i have been . |
Lo-Fi Version | Time is now: 26th June 2024 - 04:59 AM |
