Chaznaster |
Member ![]() ![]() Group: Members Posts: 305 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States ![]() ![]() |
Hi All. I was working towards getting on the road formally this spring and seem to have caused a problem while digging around the engine bay.
It's a 74 1.8 with a single Weber progressive and an 009 distributor (I know nobody likes that setup ...) and Pertronix Ignitor. We have had it running (adjusted valves and timed it) and even put a few miles on it over the last few weeks. Today, out of interest and while trying to find out my Pertronix model number, I took the cap off the dizzy, pulled the rotor and magnetic sleeve and took out the Pertronix. There was no part number (ugh). I put it all back together (it has been running, albeit not well). When starting, I got a bright flash above the engine (!) and the car tried to run but it will not idle and backfires like crazy. So much so that I am not comfortable trying to start it again. (IMG:style_emoticons/default/confused24.gif) I did check all the wires and plugs and all seems OK. I think the Pertronix is still working (it does fire). Could removing and replacing that part mess with timing or hurt the unit itself? I cannot see why but it is running like the timing is waaayyyy off. Does anyone here have any ideas on what I might have done to cause it to not run well. How about ideas of what I might do to get back on track? My only thought is to go back to points, static time it to start and go from there ... I really appreciate the help! |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
reset the gap inside the distributor with the pertronix
similar to resetting the points if you had pulled a set out and reinstalled.... |
Chaznaster |
reset the gap inside the distributor with the pertronix similar to resetting the points if you had pulled a set out and reinstalled.... I looked into that. The igniter I have does not have an adjustable gap. It locks down with a screw and pin that fits in the base. And the igniter base plate goes completely around the shaft. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:10 AM |
