> Cut slot in bell housing, ability to turn engine
930cabman
post May 17 2021, 06:15 PM
I can find no easy way to turn the engine in small increments as needed to adjust valves, static spark timing, etc. Spark plugs removed to relieve compression of course. It seems to make sense to cut a small ( 3/8 x 1/2") slot in the bell housing to allow for a screwdriver to engage with the ring gear for small adjustments.
Have a fallen off my rocker?
thanks
post May 18 2021, 11:03 AM
Resident German
As said above, put the rear in the air, car in gear, lock one wheel (with a bar etc) and turn the other ...
930cabman
post May 18 2021, 12:14 PM
QUOTE(SirAndy @ May 18 2021, 11:03 AM) *
Thanks Andy, but in this case the engine/tranny are on a bench for testing. In the future I will use your method when everything is assembled.
GregAmy
post May 18 2021, 01:03 PM
QUOTE(930cabman @ May 18 2021, 01:14 PM) *
Use a prybar in the starter hole. Piece o' cake to R&R the starter, especially on the bench.
930cabman   Cut slot in bell housing   May 17 2021, 06:15 PM
ClayPerrine   Use a 13mm socket on an extension in the center of...   May 17 2021, 08:43 PM
930cabman   Use a 13mm socket on an extension in the center o...   May 18 2021, 04:04 AM
Spoke   Use a 13mm socket on an extension in the center ...   May 23 2021, 07:14 AM
rgalla9146   4 cyl. ? Plugs out trans in 1st gear ...   May 17 2021, 08:59 PM
rjames   It wouldn't work for adjusting the valves, but...   May 17 2021, 09:04 PM
Superhawk996   Note on turning crank nose / fan hub bolt. Turn i...   May 18 2021, 06:10 AM
GregAmy   Word of warning...that 13mm hub bolt is not design...   May 18 2021, 06:53 AM
930cabman   Word of warning...that 13mm hub bolt is not desig...   May 18 2021, 12:18 PM
brant   There is also an $9 remote starter switch fro...   May 18 2021, 09:56 AM
SirAndy   As said above, put the rear in the air, car in gea...   May 18 2021, 11:03 AM
930cabman   As said above, put the rear in the air, car in ge...   May 18 2021, 12:14 PM
GregAmy   Thanks Andy, but in this case the engine/tranny a...   May 18 2021, 01:03 PM
930cabman   Thanks Andy, but in this case the engine/tranny ...   May 18 2021, 01:13 PM
Mark Henry   If the engine is out I would re-mark the fan so it...   May 18 2021, 01:00 PM
930cabman   If the engine is out I would re-mark the fan so i...   May 18 2021, 01:12 PM
VaccaRabite   I've done a good bit of playing with engines o...   May 18 2021, 01:43 PM
930cabman   I ended up installing the alternator with associat...   May 22 2021, 05:46 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th January 2025 - 10:56 AM
